steering columns
Old Jul 11, 2007 | 02:30 AM
babylonvette's Avatar
babylonvette
Default steering columns
i bought a t/tcolumn off fleabay about a year ago and was shown pics of the column ,then i think i got caught in a bait and switch, it was supposed to be a 72 column i think i wound up with a 76, it came with the vega steering wheel, i collected rest of pieces to correct the mistake, then when i installed it into the car tonight it is about 2"too short to connect to the steering box, any answers or suggestions, can i change lower shaft or use different coupler, HELP
Old Jul 11, 2007 | 02:35 AM
RunningMan373's Avatar
RunningMan373
Default Ok
Start by reading this. http://forums.corvetteforum.com/show....php?t=1728418A member posted a while ago a methode of using a come-along, with the column attatched to a stable object. Apperently they are very difficult to re-extend, but you can see the wrong methode from a previous post that I used.. ie the frustration slam methode. hey, but it worked.... Also check Jim Shea's pappers, he's the column expert.
