Silicone vs. Anti-Seize
Old Jul 14, 2007 | 05:43 PM
kaiserbud's Avatar
kaiserbud
Default Silicone vs. Anti-Seize
What is the guidance on using Silicone vs. Anti-Seize? I have an aluminum intake and am installing the water nipples... which one is a better application?
Old Jul 14, 2007 | 07:27 PM
red79vette454's Avatar
red79vette454
You should use teflon tape or the brush on teflon sealer on those pipe threads.
Old Jul 14, 2007 | 07:33 PM
Edzred72's Avatar
Edzred72
Silicone is a sealant. Anti-seize is basicaly a thread lubercant.
Eddie
Old Jul 14, 2007 | 07:43 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Go easy on the RTV, that's the most overused product next to duct tape on the planet.
Ever disassemble a motor that someone had siliconed together? The crap gets everwhere internally. I seen everything from oil pump pickups to entire radiators plugged with that crap
There are much better choices for most applications
Old Jul 14, 2007 | 10:53 PM
kaiserbud's Avatar
kaiserbud
Thanks for confirming the difference, I was justa bit confused with having an aluminum manifold whether I should be more conscious of sealing or anti-seizing....
I promise to be gentle on the RTV - promise !
Old Jul 14, 2007 | 11:24 PM
SteveG75's Avatar
SteveG75
Liquid Teflon will seal and anti-sieze.
I use the real anti-sieze on spark plugs, side pipes, metal-to-metal rotating parts in the suspension.
Old Jul 15, 2007 | 09:04 AM
schmegeggie's Avatar
schmegeggie
First, Silicone is a sealant, as stated above. It's application ranges from dressing gaskets(depending on which you use) to caulking your tub. It is a flexible product and shrinks and swells as temperature changes. However, that movement is what will cause a leak over time.
Anti-seize is a lubricant. Because of it's high temperature capabilities, it's useful with bolts that will see over 300 degrees+, an area where a threadlocker will melt away. Nickel and copper are the most common. A mechanical fastener(lockwasher) is still required because unless your torquing heads, the bolt could back out.
Threadlockers, i.e. Loctite, are used to seal threads and lock nuts to keep them from backing out. However limited in temperature rating, Loctite will protect the engaged threads and make removal(if ever needed), much easier(I may catch some flack on that one).
To Silicone vs. Anti-Seize
