Starter heat protection?
Anyone know a good heat sheild for on the starter? I took my car to my parents house, 3.5 hr drive, and the starter was fried. I put a new one in but want to protect it a bit. Any ideas?
T
T
St. Jude Donor '09-'10, '15, '17
I've used the generic ones before and they seem to help eliminate heat soak.
http://store.summitracing.com/egnsea...10&D=%2D119610
Another option. Easier to install and take out than the metal ones
http://store.summitracing.com/partde...5&autoview=sku
My 73 L82 had the "heat soak" problem. A starter shield (wrap style) from Summit helped except for real hot days. It would take 2 hours of cool down for it to restart after a run. Had the starter rebuilt, installed a few shims during the re-install and never had the problem again. Heat shield is on a shelf in the garage.
I am going to run ceramic coated block hugger headers with thermotec wrapping on the pipe to contain heat so I am not expecting any heat problems with the starter or inside the cabin
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
nope no problems at all nice and easy install
the are held in place using the existing screws on the starter, you take em out, place the shield on and re install the screws and put it in
Ive got both, but been using the blanket fro about 2 months now since i put my pipes on and no heat soak issues at all
cheers
tim
http://store.summitracing.com/partde...0&autoview=sku
i've used this heat shield now for 15yrs now n not 1 failed start, prior to that heat soak nonstarts drove me nuts
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I have starter heat issues and and I have both the flexible shield and the metal shield. I tried putting the flex shield on but there is not enough clearance between the starter and engine. Can anyone share pics and/or insrtuction on the installing the metal type.
it's a simple install. it uses 2 bolts on the starter on each side, one is the long bolt of the starter on the front and the other is a small bolt on the back of the starter towards the rear of the car. i've got a 1/4" clearance between the heatshield and my headers and about the same distance between the heatshield and the block on the top of the shield.
