quick question about balancer gap
Old Jul 16, 2007 | 03:19 PM
smon's Avatar
smon
Default quick question about balancer gap
should there be this big of a gap on my harmonic balancer. im using an installer and i cant turn it anymore, i dont want to strip the threads.
thanks
sean
Old Jul 16, 2007 | 03:27 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Looks right. If that is the original timing tab and timing chain cover, you will notice from pic that timing mark on balancer will just be visible as it comes around.
If in doubt, do a visual line up with the pulleys for other parts - water pump, ps pump, alternator, etc.
But if balancer feels bottomed out to crankshaft - you are fine.
That is why you use a balancer installer instead of a big ol' hammer!
Bman
Old Jul 16, 2007 | 03:43 PM
Durango_Boy's Avatar
Durango_Boy
I bottomed out once when installing a balancer and it wasn't seated properly against the shoulder. I would think there would be less of a gap.
Did you lubricate the snout at all before installing the balancer? I had to pull mine off, lube everything including the threads on the installer, and try again. The following time it slid on all the way and seated properly.
Old Jul 16, 2007 | 04:41 PM
smon's Avatar
smon
yeah i lubed it pretty well and the installer had a little on it. it seems like its as far as it will go.
ill put the pulleys on and see if they line up with the others
Old Jul 16, 2007 | 05:00 PM
GD70's Avatar
GD70
That balancer looks pretty old. Is the rubber ok? This is a good time to replace it. Just curious why you needed to pull the balancer?
Old Jul 16, 2007 | 05:12 PM
smon's Avatar
smon
the pulleys didnt line up exactly so i relubed everything and it finally seated more. the pulleys line up now.
on the last turn of the nut, the threads on the adapter to the crank to the installer broke off into the crank threads, but luckily i was able to use needle nose and get it out.
i was told it was ok(it seemed fine before too), but i may go ahead and replace it, what happens if i dont and its bad?
i put a new cam in, so i had to pull everything off.
Old Jul 16, 2007 | 05:22 PM
Durango_Boy
You lucked out. I hate when install tools break and cause a lot of headaches with removals.
A bad balancer will cause all kinds of problems with your timing and sometimes they're hard to diagnose if you don't already know where to look.
To quick question about balancer gap
