[73]WTF is this wire
Old Jul 17, 2007 | 07:25 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default [73]WTF is this wire
That green wire that is sticking up there.
Old Jul 17, 2007 | 07:32 PM
ShaneLU97's Avatar
ShaneLU97
Does / did the car have a/c? It looks like one of the control wires for the A/C system....maybe. Put a voltmeter on it and see what it does when you turn the switches on and off.
Old Jul 17, 2007 | 08:03 PM
Guru_4_hire
Cruise-In V Veteran
Stays pretty steady at .04V
Old Jul 17, 2007 | 08:08 PM
Gordonm's Avatar
Gordonm
I think that might be the wire for the thermal switch in the cylinder head. Part of the emission crap!
Old Jul 17, 2007 | 08:10 PM
chris73cpe's Avatar
chris73cpe
there is a green wire that goes from that harness to the ac compressor clutch as said. I can't tell from your pic, but does it go to the temp switch in the passenger head? mine is long gone so I don't know what color wire is supposed to be on that.
Old Jul 17, 2007 | 08:18 PM
Guru_4_hire
Cruise-In V Veteran
I think it is the Air compressor clutch wire.
I have another frayed wire that I have no clue what it is. It might be the passenger side thermal switch.
I am trying to find out my fan doesnt work.
Do I need the A/C clutch to make my fan work?
Old Jul 17, 2007 | 08:23 PM
Gordonm's Avatar
Gordonm
I
I don't think so because the fan should work for the heater also which does not matter if the Ac clutch is there or not.
Old Jul 17, 2007 | 08:26 PM
Guru_4_hire
Cruise-In V Veteran
OK so we are good there.
There is a dark green wire comming off of a single connector right next to the A/C box. Is that the temperature sensor for the emissions?
So where is a good place to start on the fan?
Old Jul 17, 2007 | 08:34 PM
Guru_4_hire
Cruise-In V Veteran
How do I test the A/C Relay?
Old Jul 17, 2007 | 08:38 PM
Guru_4_hire
Cruise-In V Veteran
Holy Crap a blown Fuse!
Old Jul 17, 2007 | 08:45 PM
RunningMan373's Avatar
RunningMan373
My Schems say the only white/green wire in the engine compartment is the Headlamp door warning switch wire, goes to 2 switches. Are your hdlp warning switches hooked up? If they are, you get a warning buzzer when you turn on the headlights, but before they deploy fully.
Old Jul 17, 2007 | 09:17 PM
redwingvette's Avatar
redwingvette
OK I took some pics of my 73
These wires are for the speed control. Hugh speed conects 12volts direct to the blower motor by a relay mounted on the side of the AC box. below the thermal relay
The wires here conect to the blower box below
The green wire from the thermal fuse goes to the compressor
Hope this helps.
Old Jul 17, 2007 | 09:28 PM
Guru_4_hire
Cruise-In V Veteran
Thats great thanks
To [73]WTF is this wire
