pump gas vs. compression
Old Jul 18, 2007 | 01:48 PM
mo69's Avatar
mo69
Default pump gas vs. compression
Looking for input on building a 383 with 10.4 compression vs. a 415 with 9.0 compression. My main concern is running pump gas with the 383. I've used the "search" but wasn't able to find what I'm looking for. Any input or opinions would be appreciated.
Old Jul 18, 2007 | 02:37 PM
BKbroiler's Avatar
BKbroiler
This might help a little - my 383 has a calculated CR of 9.7 to 1. I use 93 octane gas with no problems at all.
Old Jul 18, 2007 | 02:41 PM
jimvette999's Avatar
jimvette999
what cam and heads are you planning on using?
Old Jul 18, 2007 | 03:14 PM
big_G's Avatar
big_G
My al. head 383 (big cammed) ran fine on 93 with a c/r of 11:1
Old Jul 18, 2007 | 03:30 PM
weimer20's Avatar
weimer20
I run slightly over 10/1 compression ration on mine. Here in California I can only get 91 octane from the pumps. Mine is REALLY sensitive to timing. I have to run mine with the timing backed off a bit to prevent the "rattles". We have crappy gas in California though due to all the smog stuff. I'm using an iron head though and I understand that an aluminum head will tolerate a bit more. If I were to build the engine again, given what I know now, I would knock the compression down a half a point. Another poster inquired on your cam choice. This does have a lot to due with this issue!
Old Jul 18, 2007 | 08:44 PM
Gordonm's Avatar
Gordonm
I am running a 385 with 10.4 to 1 compression. Running decent high grade fuel I don't have a problem. I am running a big solid cam which helps some. Notice I did say DECENT fuel. I have run some premium that is real crap.
Old Jul 18, 2007 | 11:07 PM
SteveG75's Avatar
SteveG75
Do a google on Dynamic Compression Ratio.
Static Compression Ratio is good for nothing but bragging rights. You can (and need to) run more static compression with a big cam. Remember, the mixture will not compress till the cylinder is air tight. Than means the valves have to be closed.
Like most things in life, (valve) timing is everything.
Old Jul 18, 2007 | 11:10 PM
Kalway's Avatar
Kalway
Your dynamic compression ratio is really what's important.
To pump gas vs. compression
