1969 Corvette stingray (427)
drive = RWD [ steering ] max-angle = [ engine ] position = mass = max-power = peak-engine-rpm = rpm-limit = inertia = idle = start-rpm = stall-rpm = fuel-consumption = 1.779e-8 [ clutch ] sliding = radius = area = max-pressure = [ transmission ] gears = 4 gear-ratio-r = gear-ratio-1 = gear-ratio-2 = gear-ratio-3 = gear-ratio-4 = gear-ratio-5 = gear-ratio-6 = shift-delay = [ differential ] final-drive = anti-slip = [ fuel-tank ] position = capacity = volume = fuel-density = [ suspension-front ] spring-constant = bounce = rebound = travel = max-compression-velocity = camber = caster = toe = anti-roll = [ suspension-rear ] spring-constant = bounce = rebound = travel = max-compression-velocity = camber = caster = toe = anti-roll =
[ tire-front ] radius = rolling-resistance = rotational-inertia = # Lateral force a0= a1= a2= a3= a4= a5= a6= a7= a8= a9= a10= a111= a112= a12= a13= # Longitudinal force b0= b1= b2= b3= b4= b5= b6= b7= b8= b9= b10= b11= b12= # Aligning moment c0= c1= c2= c3= c4= c5= c6= c7= c8= c9= c10= c11= c12= c13= c14= c15= c16= c17= [ tire-rear ] radius = rolling-resistance = rotational-inertia = # Lateral force a0= a1= a2= a3= a4= a5= a6= a7= a8= a9= a10= a111= a112= a12= a13= # Longitudinal force b0= b1= b2= b3= b4= b5= b6= b7= b8= b9= b10= b11= b12= # Aligning moment c0= c1= c2= c3= c4= c5= c6= c7= c8= c9= c10= c11= c12= c13= c14= c15= c16= c17=
[ brakes-front ] friction = max-pressure = bias = radius = area = [ brakes-rear ] friction = max-pressure = bias = radius = area = [ driver ] position = mass = view-position = [ drag ] position = frontal-area = drag-coefficient = [ wing-front ] position = frontal-area = drag-coefficient = surface-area = lift-coefficient = efficiency = [ wing-rear ] position = frontal-area = drag-coefficient = surface-area = lift-coefficient = efficiency = [ wheel-FR ] position = roll-height = mass = restitution = [ suspension-FR ] position = hinge = [ wheel-FL ] position = roll-height = mass = restitution = [ suspension-FL ] position = hinge = [ wheel-RR ] position = roll-height = mass = restitution = [ suspension-RR ] position = hinge = [ wheel-RL ] position = roll-height = mass = restitution = [ suspension-RL ] position = hinge = [ contact-points ] # used to find the bounds of the car (for collisions) # also play into the weight distribution and balance mass = position-00 = position-01 = position-02 = position-03 = position-04 = position-05 = position-06 = position-07 = # these are used to calculate the weight distribution and balance [ particle-00 ] mass = position = [ particle-01 ] mass = position = [ particle-02 ] mass = position = [ particle-03 ] mass = position = [ particle-04 ] mass = position = [ particle-05 ] mass = position =
P.S. PHOTOS of the interior and exterior are needed (color does not matter we can edit in photoshop) try to make sure there clear (and stock as possible) so that we can have one great car!
(visit www.vdrift.net to see this project!)
. (the problem is i am going to europe ugust 2nd!
) and different rear end ratios were also available.
OK, I do not have a 427-'69 Vette but since I wish I did, I'll try to answer some of you questions.
Drive=RWD (we agree on that one).
HP/Torque=Sheet Loads.
Babe Magnet=Hard to top.
OK...That was fun, but seriously, I think it would take a GM Engineer to answer most of your questions. I'm not sure where you are located but I'm sure there is a Forum member in your area with a 427-'69 who would enjoy showing you their car and helping you figure out this data. What is your location?
Good Luck with your project and let us know how it goes.....gp
. Here is an example. and YES i have done A LOT of googling. (this is for the Z06 corvette that we already modelled.)drive = RWD [ steering ] max-angle = 36.0 [ engine ] position = 1.4, 0.0, -0.1 mass = 200.0 max-power = 2.871e5 peak-engine-rpm = 6000.0 rpm-limit = 6500.0 inertia = 0.5 idle = 0.025 start-rpm = 1000 stall-rpm = 500 fuel-consumption = 0.0001 torque-friction = 0.001 torque-curve-00 = 1000, 361.04 torque-curve-01 = 2000, 380.10 torque-curve-02 = 2500, 389.70 torque-curve-03 = 3000, 396.24 torque-curve-04 = 3300, 414.09 torque-curve-05 = 3500, 435.71 torque-curve-06 = 3800, 450.14 torque-curve-07 = 3900, 462.89 torque-curve-08 = 4000, 472.37 torque-curve-09 = 4100, 477.32 torque-curve-10 = 4200, 483.11 torque-curve-11 = 4400, 480.30 torque-curve-12 = 4600, 469.45 torque-curve-13 = 4900, 450.12 torque-curve-14 = 5500, 428.78 torque-curve-15 = 6000, 380.61 torque-curve-16 = 6500, 336.0 [ clutch ] sliding = 0.27 radius = 0.05 area = 0.12354 max-pressure = 4.9e5 [ transmission ] gears = 6 gear-ratio-r = -3.28 gear-ratio-1 = 2.97 gear-ratio-2 = 2.07 gear-ratio-3 = 1.43 gear-ratio-4 = 1.00 gear-ratio-5 = 0.84 gear-ratio-6 = 0.56 shift-delay=0.08 [ differential ] final-drive = 3.42 anti-slip = 400.0 [ fuel-tank ] position = -1.2, -0.1, -0.26 capacity = 100.0 volume = 100.0 fuel-density = 0.8 [ suspension-front ] spring-constant = 60000.0 bounce = 7000.0 rebound = 7500.0 travel = 0.12 max-compression-velocity = 10.0 camber = -1.33 caster = 6.12 toe = 0.0 anti-roll = 10000.0 [ suspension-rear ] spring-constant = 45000.0 bounce = 5500.0 rebound = 6000.0 travel = 0.12 max-compression-velocity = 10.0 camber = -0.45 caster = 0.28 toe = 0.2 anti-roll = 10000.0 [ tire-front ] radius = 0.3284 rolling-resistance = 1.3e-2, 6.5e-6 rotational-inertia = 10.0 tread = 0.0 # Lateral force a0=1.3 a1=-49 a2=1216 a3=1632 a4=11 a5=0.006 a6=-0.04 a7=-0.4 a8=0.003 a9=-0.002 a10=0.16 a111=-11 a112=0.045 a12=0.17 a13=-23.5 # Longitudinal force b0=1.57 b1=-48 b2=1338 b3=6.8 b4=444 b5=0 b6=0.0034 b7=-0.008 b8=0.66 b9=0 b10=0 b11=0 b12=0 # Aligning moment c0=2.46 c1=-2.77 c2=-2.9 c3=-0 c4=-3.6 c5=-0.1 c6=0.0004 c7=0.22 c8=-2.31 c9=3.87 c10=0.0007 c11=-0.05 c12=-0.006 c13=0.33 c14=-0.04 c15=-0.4 c16=0.092 c17=0.0114 [ tire-rear ] radius = 0.3284 rolling-resistance = 1.3e-2, 6.5e-6 rotational-inertia = 10.0 tread = 0.0 # Lateral force a0=1.3 a1=-49 a2=1216 a3=1632 a4=11 a5=0.006 a6=-0.04 a7=-0.4 a8=0.003 a9=-0.002 a10=0.16 a111=-11 a112=0.045 a12=0.17 a13=-23.5 # Longitudinal force b0=1.57 b1=-48 b2=1338 b3=6.8 b4=444 b5=0 b6=0.0034 b7=-0.008 b8=0.66 b9=0 b10=0 b11=0 b12=0 # Aligning moment c0=2.46 c1=-2.77 c2=-2.9 c3=-0 c4=-3.6 c5=-0.1 c6=0.0004 c7=0.22 c8=-2.31 c9=3.87 c10=0.0007 c11=-0.05 c12=-0.006 c13=0.33 c14=-0.04 c15=-0.4 c16=0.092 c17=0.0114 [ brakes-front ] friction = 0.6 max-pressure = 3.8e6 bias = 0.6 radius = 0.18 area = 0.01 [ brakes-rear ] friction = 0.6 max-pressure = 3.0e6 bias = 0.4 radius = 0.15 area = 0.01 handbrake = 1.0 [ driver ] position = -0.68, 0.3, -0.2 mass = 90.0 view-position = -0.68, 0.3, 0.3 hood-mounted-view-position = 0.5, 0, 0.2 [ drag ] position = 0.0, 0.0, -0.60 frontal-area = 2.0 drag-coefficient = 0.3 [ wing-front ] position = 2.34, 0, -0.6 frontal-area = 0.2 drag-coefficient = 0 surface-area = 0.3 lift-coefficient = -0.5 efficiency = 0.95 [ wing-rear ] position = -2.14, 0, 0.37 frontal-area = 0.2 drag-coefficient = 0 surface-area = 0.5 lift-coefficient = -0.5 efficiency = 0.95 [ wheel-FR ] position = 1.30, -0.66, -0.46 roll-height = 0.2 mass = 26.0 restitution = 0.1 [ suspension-FR ] position = 1.30, -0.51, -0.32 hinge = 0,0,-0.1 [ wheel-FL ] position = 1.30, 0.66, -0.46 roll-height = 0.2 mass = 26.0 restitution = 0.1 [ suspension-FL ] position = 1.30, 0.51, -0.32 hinge = 0,0,-0.1 [ wheel-RR ] position = -1.25, -0.66, -0.48 roll-height = 0.2 mass = 26.0 restitution = 0.1 [ suspension-RR ] position = -1.25, -0.51, -0.32 hinge = 0,0,-0.1 [ wheel-RL ] position = -1.25, 0.66, -0.48 roll-height = 0.2 mass = 26.0 restitution = 0.1 [ suspension-RL ] position = -1.25, 0.51, -0.32 hinge = 0,0,-0.1 [ contact-points ] # used to find the bounds of the car (for collisions) # also play into the weight distribution and balance mass = 33 position-00 = -2.32, 1.11, -0.62 position-01 = 2.32, 1.11, -0.62 position-02 = -2.32, -1.11, -0.62 position-03 = 2.32, -1.11, -0.62 # these are used to calculate the weight distribution and balance [ particle-00 ] mass = 248 position = -2.3, 1.11, -0.22 [ particle-01 ] mass = 248 position = -2.3, -1.11, -0.22 [ particle-02 ] mass = 218 position = 2.3, 1.11, -0.22 [ particle-03 ] mass = 218 position = 2.3, -1.11, -0.22
(sorry for all errors im rushing
[CODE]drive = RWD
You will need to give them the VIN, year and make , and they will sent you this package for free, I got mine in about two weeks, and it has everything you want, plus info on GM< certified distributor
cheers
Tim
!I am always amazed at noobs who log on looking for instant gratification on out in left field questions, especially the kind you want.
Like its the forums fault you couldnt get an answer in 20 seconds flat.
you dont post any info on your self, dont fill out a profile, and ask for information to do some project that Only a "true expert" can answer (as opposed to all us fake experts) and then complain that no once can give you MFG/ engineering level information based on your schedule
God forbid we should upset your travel plans
ahhh to be 17 again
sheesh
Good things come to those who wait, Call GM and get thier restoration package, and have a little patience
Rant over, flame me if you will, I can take it
now im not in the mood to flame. is there some way i can obtain a vin on this car? hmmmm come to think of it i have a cousin who works at GM:o im going to give him a call and ask him to get me some info if he can. thanks for your help anyway. P.S. (17/2)+(9/2) = My Age. Figure it out.
P.P.S (i will stay active on the corvette forums anyway...
Well I can tell you that with your engine specifications there is going to be a horsepower deviation for even an engine with the same specifications. I would find out what type of transmission you have ie. m20, m21, m22 and then find out your gear ratio, and then find out your tire height yadayayayya.
Pretty bright for a 13 year old.
P.S. This is the 21st century my friends. men now babysit. i know how this may shock some of you. but i really want that lexus so i can sell it for a 'vette! (i cant wait to wax my 'vette)
