68 ignition switch
Old Jul 23, 2007 | 10:31 PM
AWilson's Avatar
AWilson
Default 68 ignition switch
My 68 ignition switch doesn't work properly. I had trouble taking it apart because it appears that the threaded bezel that holds the switch onto the dash is smaller than the ignition lock. It only unscrews so far until it hits the ignition lock then I had to cut it to get it off.
Have others had this problem? I ordered all new parts (EXPENSIVE) and think the assembly sequence is that the nut goes on first to hold the switch in place on the dash. Then the lock.
Anyone confirm or advise otherwise?
Old Jul 23, 2007 | 10:42 PM
big_G's Avatar
big_G
Put key into "accessory" position
Insert and push an opened paper clip in hole in bezel and turn key counter-clockwise while pulling cylinder out.
Then unscrew the bezel nut.
Old Jul 23, 2007 | 11:36 PM
AWilson's Avatar
AWilson
Default Big G how about installation?
Thanks Big G.
On reassembly how does the cylinder go in after the nut? Use paper clip also?
Old Jul 23, 2007 | 11:47 PM
big_G's Avatar
big_G
No paper clip. Just insert it as you removed it, and turn clockwise to lock in place. (After the bezel nut...lol)
Old Jul 24, 2007 | 12:00 AM
AWilson's Avatar
AWilson
big thank you!
Old Jul 24, 2007 | 01:33 PM
big_G's Avatar
big_G
your welcome
Old Jul 24, 2007 | 03:26 PM
427-390's Avatar
427-390
That's the ticket!
Old Aug 3, 2007 | 10:52 PM
AWilson's Avatar
AWilson
Went together with noooo problems. Simple with a little help from forum members.
Thanks guys!
Old Jun 13, 2009 | 05:03 PM
roscobbc's Avatar
roscobbc
Default Removal of '68 Ignition Switch
I have just experienced this issue trying to remove '68 ignition switch which seized-up (just before going to car show) And here lies the problem - I can't go through the putting pin in hole and turning key to accessory position as the tumblers appear to have jammed - any suggestions guys.
Old Jun 13, 2009 | 07:55 PM
roscobbc's Avatar
roscobbc
Well - Iv'e managed to remove the ignition switch - it appears that the barrel assembly is the problem - one of the tiny springs on the lever shutter bar was missing causing the jam - still need to get a new barrel.
To 68 ignition switch
