Muscle car engine shootout (BS)
. What a load of BS for a stock motor. Next is the 426 Hemi, it pulls 800+ HP
WHAT!!. No freaking way with stock heads and stock cam. The L88 Chevy was next and it pulled 530 HP with headers. This is in range of what they pull. Who were they kidding with these numbers. Are they a little pro Mopar and Ford? This was all done on the same dyno with the same operators supposedly. 3 motors I can believe but the Ford and Hemi no way.
This may be an older show that some have seen but I was shocked that they even put these numbers up.
Utter propaganda...
A very rare BB by any standard. 57 total produced (1963).
I remember hangin' with the boys, at the drag strip, back in 63. One friend had a 63 Ford Sedan w/Lightweight goodies added (fiberglass hood, doors and trunklid, aluminum bumpers and tranny, no radiio, no ashtray, no armrests, no carpet, etc) that was a little tweaked.
We actually drove up to Detroit and met with some of the engineer's who helped with some tips for setting the car up for all out strip competition (Welded spider gears, drilled holes in the frame, removed every other fender bolt, pre-loaded springs, etc, etc).
I remember the Z-11 equiped Chevy just never quite got it done, while a 426 Wedge was constantly kickin' butt on the local scene.
Meanwhile, as I recall, the "A" stock national record was held by Don Gay with a Pontiac GP with a 421 for the years 61, 62 & 63 (13 flat for the 1/4).
NHRA history records don't seem to go back past 74...
When they were dynoing the 409, I was watching the readout on the dyno and it read 420hp, but it dropped to 409 at the end of the pull, yet they recorded the peak at 409hp
You could listen to the 427 ford and the Hemi and tell they were HIGHLY modified engines.....They blew threw the pull so fast it wasn't even funny. I mean seriously, 800hp out of a 426 hemi? yeah, maybe on a 250hp shot of gas.
The 409/L88/389 were probably stock motors but...the others were total BS. That show is a joke.
They should have used the same dyno for all engines. Do you think some of the dyno operators were also the builders?
A friend of mine used to run sprints on a local dirt track back in the late 60's. He ran 427 tunnel ports which he bought directly from ford for $505 each, drop shipped to his door.
I watched the same show and was also struck by the power of the 427 Ford and the Hemi, even somewhat skeptical. However, you should drive over to Pitman and talk to Rich Morley just outside of town on Delsea Drive. Back in the 60's he and his Dad and brother built many of the engines that ran at Atco. Rich ran a '66 or '67 427 Fairlane and held the A Stock record at Atco for a few years with his Fairlane. The car was awesome and no-one could touch it.
While I was surprised by the numbers, I do remember well the 427 Fords back then including a few that ran in the modified class at many of the local circle tracks in South Jersey. They were rare and expensive to run, but were killers when they did.
I believe Mr Morley has now semi-retired and they are no longer known for building such awesome race motors, but one of the sons is still doing some machine work. Plan to spend some time, because Mr Morley is a heck of a story teller...
GUSTO
The 427 Ford was supposed to be a FE motor.
I beleive they were a bit biased on their reports.
Your point was well taken by the way and I would be surprised to learn that he was making 600 hp... but not shocked...
GUSTO
The 427 SOHC motor made 615 hp @ 7000 rpm with a single 4 barrel. The 8 barrel motor made 657 hp @ 7500 rpm.
