Rear spring (detective work) problem
What do you think?
Thanks for your input!
Mike
When off the ground the trailing arms are loose as a goose.You cant check anything if the tires are off the ground or when hanging on jackstands.Check your diff. yokes and strut rod bushings.Also make sure the main leaf is not broke at the diff. center pin.
I smell
I have to say, I didn't consider your comment that the wheel might not hang exactly correct when up on jack stands.. Humm. I'll have to check the clearance now that the car is down. Also, I have hand sanded & repainted the entire frame from front to rear and I can tell you that I never found any buckling or inconsistancies anywhere.
The frame appears solid and straight to the eye. So, if there is a problem, it would seem that it might be somewhere with the control arm
or something other than the frame.
Also, you are absolutely right about the gas tank. It appears that the position would depend on where it is strapped in. The tank looks to have been recently repaired, the might have put it back in slightly off center.
Well, I don't know exactly what it is but I don't think it's a frame problem.. $800.00 bucks? I'll buy you a round of beers!!
