MSD Ignition
Old Jul 28, 2007 | 09:57 AM
johnmisk's Avatar
johnmisk
Default MSD Ignition
Hello to all, Nubie to the forum here. I have a 1971 Coupe with stock 350 and factory air. I'm presently running with Pertronix ignition installed in the original distributior. I've recently purchased an MSD box to add to the setup. I'm presently at a loss as to where to put the box. If anyone on the forum has added MSD, where did you mount the box? Thanks to all. John
Old Jul 28, 2007 | 12:58 PM
Duke94's Avatar
Duke94
Do a search of the forum as there have been many threads of MSD locations with pictures.
Old Jul 28, 2007 | 01:28 PM
jcswm's Avatar
jcswm
Every time I do a search i get 11 pages of posts from every section on here that seems like it's NOTHING like what I'm looking for...... Am I just doing something wrong???
Welcome aboard Johnmisk you'll get an answer soon
Old Jul 28, 2007 | 01:46 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
http://forums.corvetteforum.com/show....php?t=1766054
Old Jul 28, 2007 | 06:41 PM
'Bochawa72's Avatar
'Bochawa72
Here ya go. I only have three of the mounts on but it's pretty stable. It's definately not going anywhere.
-CR
Old Jul 28, 2007 | 10:13 PM
BillPk's Avatar
BillPk
Trash can is good.
Old Jul 29, 2007 | 09:33 AM
dmaaero's Avatar
dmaaero
I see a lot of these things mounted upside down, msd clearly states do not mount upside down there"s a drain in the bottom to let mostiure out!
Old Jul 29, 2007 | 09:41 AM
wbulick76's Avatar
wbulick76
You took the words right out of my mouth!
Old Jul 29, 2007 | 02:25 PM
'Bochawa72's Avatar
'Bochawa72
Hmmm.... I figured that upside down meant with the bottom of the box facing the sky. I figured that mine was mounted sideways. I'll have to go back and look throught the manual again. Thanks for the heads up though.
-CR
Old Jul 29, 2007 | 09:37 PM
Roughrider's Avatar
Roughrider
I have an MSD mounted in my '69 behind the passenger side of the dash. The panel comes off easily and makes the MSD invisible, plus it's away from direct engine heat.
To MSD Ignition
