Are the motor mounts pretty easy to replace, meaning are they easy to get to? Would I be able to do it with just two jack stands, floor jack, and hand tools?
It's easy enough to do with basic tools, but you may want a device to lift the motor from the top a few inches. I don't like jacking from the bottom pan.
The rubber mount are meant to isolate the frame from engine vibrations and allow the engine to torque-over a bit. Solid mounts are stronger, directly tie the engine to frame and during heavy launches keeps the drive train in alignment. For street driving I'd go with rubber-a good set from Energy Suspension. For drag racing I'd go with the solid steel. Don't forget the trans mount - you have a rubber vs. solid choice here too.
With solids,you can expect to have some bolts vibrate loose occasionally...header bolts,power steering pivot bolt, bracket,etc....I've had to loctite some of mine on the 69 502...
Eeek! That's something I hadn't considered before ordering my solid mounts. I should get them next Thursday.
its up to you but ,if your mounts are not broke why do you want to change them ?
Mounts can be busted and look fine. My driver's side looked great, until I started taking it off...stupid thing was separated.
1 - Energy Suspension doesn't make rubber ANYTHING.
2 - there are three choices at every point - rubber, POLY or solid.
3 - don't install solids at all three points - if using solid engine mounts, use a rubber or poly trans mount. Otherwise, that aluminum transmission case will likely crack.
4 - there are a number of guys here running solids on the street with no problems at all. Run an archives search for info on the pros/cons of the swap in a C3.
First I've heard of that problem, and there are quite a few guys around here running solids.
From: Las Vegas - Just stop perpetuating myths please.
Try bolting the rubber mounts.
I used the ol' hot rodder trick - drill a hole through the stock type rubber mounts and install a 1/4-20 bolt & lock nut (no room for washers). Actually i had 2 holes in the metal brackets so i just drilled on through the rubber and installed 2 bolts. Use thin lock nuts only snugged on - no torque - allows the mount to sqiwish the rubber some for vibration dampning. Has worked great so far but few miles due to wiped cam (another story).
I had the old mounts give at the drag strip and eat the fan shroud so i needed to do something. Maybe the old mounts were broke from the trans-shop or previous owner - who knows? But i feel this is the best fix now and never liked the poly mounts nor solid mounts.
I just installed the POLY engine mounts- I think they were Energy Suspensions, from Summit. I'm really happy with them. You can feel a little more engine vibration and thats a good thing - not offensive. They should last forever.
