Engine Before & After
Old Jul 29, 2007 | 04:22 PM
column5's Avatar
column5
Default Engine Before & After
Due to leaky valve stem seals and bad lifters, I had to rebuild the top end of my engine. My dad and I completed the project yesterday.
Before...
After!
Also reconditioned the air box and put a new rubber seal on it...
My engine compartment has a long way to go, but at least now I'm not embarassed to show it. Oh, and I'm not burning oil a quart a week anymore and the lifters are quit, which is nice.
Old Jul 29, 2007 | 04:24 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
nice job
Old Jul 29, 2007 | 04:36 PM
Jims79's Avatar
Jims79
good job, you should have painted the rad fan while you were at it. Next time.
Old Jul 29, 2007 | 04:37 PM
Glassbowtie77's Avatar
Glassbowtie77
Looks good!
Old Jul 29, 2007 | 04:42 PM
SmokinBBC's Avatar
SmokinBBC
Nice job...good feeling ain't it?
Old Jul 29, 2007 | 04:53 PM
Deron's Avatar
Deron
looks good!
Old Jul 29, 2007 | 05:25 PM
Le shark81's Avatar
Le shark81
Nice job.
Paint does wonder on your engine
Old Jul 29, 2007 | 05:40 PM
hotshot79's Avatar
hotshot79
nice work , you are on your way now. it's harder to do a piece at a time but seeing the big difference should give you the dose of enthusiasm to keep at it.
Old Jul 29, 2007 | 05:45 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
HEY,,,,Looks great....Where did you find the fast idle solonoid.......NEW...?????
I been looking for a new one for my 74 - 454 ???
Old Jul 29, 2007 | 07:10 PM
Prestige593's Avatar
Prestige593
Give me some pointers on how you did it. I have my valve covers off now, and also would like to freshen up the look of the engine / bay. What did / didn't you remove? What did you use to clean / paint things?
Old Jul 29, 2007 | 07:23 PM
column5's Avatar
column5
Thanks everyone! It was a big job and it feels good to be done.
That came from NAPA. I'll look and see if I can find the part number, it might be on the sticker on the solenoid. We have a NAPA distribution center here in Memphis so we can walk in and get anything they would normally have to order.
Old Jul 29, 2007 | 07:33 PM
column5's Avatar
column5
We took the manifold and heads off and sent them to a shop, so everything came off of the top of the engine. I used the Duplicolor engine paint from AutoZone. With the valve covers, I cleaned all the crud off of them with gasoline, then sanded them with a fine grit sandpaper until they were really smooth. The duplicolor paint goes on nicely and dries quickly. I plan on painting some of the other exposed engine parts with a brush later. As someone mentioned above, I should have taken the fan out and painted it...will have to do that another day.
On the subject of valve covers, I highly recommend getting a set of the Permadry Plus gaskets from FelPro. I haven't had any leaks since I switched to them a coule of months ago.
Old Jul 29, 2007 | 07:36 PM
fotyfobravo
OK...NAPA.....I probably haven't checked there. NAPA is pretty good at some of the stuff that autozombie "can't get".
Thanks for the info.............
Old Jul 29, 2007 | 07:39 PM
James B's Avatar
James B
Where did you get the new air cleaner seal?
Old Jul 29, 2007 | 07:51 PM
column5's Avatar
column5
Davies' Corvette
http://www.corvetteparts.com
I order a lot of stuff from them.
Old Jul 29, 2007 | 08:57 PM
724544SPD's Avatar
724544SPD
Nice job. It's always a great feeling when you get it all back together.
Old Jul 29, 2007 | 09:05 PM
Green73's Avatar
Green73
Davies' Corvette
They are great people there. They're a few miles up the road from here. Super friendly and know me by name. Very vette knowledgeable too. Helps that the guy (the one I deal with anyway) has a vette too. Engine looks good! Keep up the good work!
Old Jul 30, 2007 | 11:10 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Looking good so far.
Old Jul 30, 2007 | 11:38 AM
markdtn's Avatar
markdtn
Nice An "aerosol overhaul" goes a long way to make you prouder of your car.
To Engine Before & After
