Changed over complete front suspension on my 69. Filled the parts with new grease but 1 of the lower ball joint boots has a small hole in it about the size of the head of a small pin. Really dont want to do battle with the coil spring again if I dont have to ,but dont want to loose grease. Any sugestions besides taking it back apart? Thanks
But with the car still on the stands grease comes out of it. When it has the tire on and its on the ground driving and turning wont I loose a lot more? Thanks
Squeese some greese out and spray it with carb cleaner to clean it and put a bike tube patch on it??. Or some silicone??. Just a sugestion..
OK thanks for the suggestions, will clean it up and try a dab of sealant, give it some good drying time and fill it with grease. appreciate the replys. Thanks
This is going to sound crazy, but Yamaha (motorcycles--not guitars) has great sealant and its black! How did I find out? I went to the Harley dealer for sealant to bond my shovelhead cases together, and he sent me to the Yamahammer store ("That's what we use....")
From: Show me a cold beer and I will show you a happy man Maryland
I would use some laqour thinner or carb cleaner first followed by denat alcohol, scuff with scotch brite, denate alcohol, and seal .The reason I would'nt use carb cleaner right before sealing is that it may leave residue that sealant will not bond properly to, where as denatured alcohol leaves no real residue after it evaporates. May seem excessive but if that does not get it clean then I dont know what will!!
OK Hers what I did. Bought a rubberpatch at the local flaps, cleaned it, scuffed it and glued it on. Will give it a few days before I regrease it. Thanks everybody.
