76 steering wheel issue
Old Aug 2, 2007 | 07:22 PM
pete44's Avatar
pete44
Default 76 steering wheel issue
Hi...new to this site and just purchased a '76 vette fixer-upper in Indiana..If you are ever in Bowling Green KY check out the Corvette Museum there.I tried but it was closed...anyhow..My steering wheel sits "straight" across when wheels are straight at idle...when I start driving it sits almost 180 degrees out when I am driving straight...What gives???....thanks,Pete
Old Aug 2, 2007 | 11:06 PM
Jim Shea's Avatar
Jim Shea
The steering wheel is mechanically connected to your front wheels. Engine on or engine off; it does not make a difference with respect to your steering wheels and front wheels.
This paper will help you to determine if you have a problem and the cause.
http://jimshea.corvettefaq.com/wp-co...Rev18MY061.doc
Jim
Old Aug 3, 2007 | 08:54 AM
Kilroy1024's Avatar
Kilroy1024
I get the feeling someone is yanking our chain.
If I'm wrong, then please restate your problem,
What your describing is impossible.
Old Aug 3, 2007 | 09:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by pete44
...If you are ever in Bowling Green KY check out the Corvette Museum there.I tried but it was closed...
When were you there? The NCM is open seven days a week and only closes on Thanksgiving and Christmas. Did you drop by after hours?
Old Aug 3, 2007 | 04:37 PM
pete44's Avatar
pete44
Thanks for the quick replies!...No, I am not pulling nobody's chains here (I wish I was)... ....I have the "dreaded Vega" type steering wheel and I drove it in to work today...the straight bars across the wheel were nearly up and down (a little more to right of center) while driving straight down highway...I appreciate the document and will look into it...I got to the National Corvette Musuem a little after 5 PM...and people walking out said they just closed...Maybe they were "yanking my chain" ......Thanks again,Pete
To 76 steering wheel issue
