Chrome Window Trim Removal?
Old Aug 3, 2007 | 03:34 PM
Me80C3's Avatar
Me80C3
Default Chrome Window Trim Removal?
I'd like to remove the chrome window trim to prep for painting.
Any tips on proceedure and tools?
Old Aug 3, 2007 | 03:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There's a tool for this. Get the tool. Any other method of removal risks bending the trim.
Old Aug 3, 2007 | 04:30 PM
Erics Quick71's Avatar
Erics Quick71
Which trim is he talking about?
The trim attached to the wiper cover?
The previous owner painted that chrome to match the car, but he was missing the passenger side corner trim.
I am not sure how to proceed?
Should I remove the painted trim and have it rechromed? Can you?
Or paint the brand new piece the best I can to try and match?
May be tough since its on chrome.
Do "I" need that specal tool as well?
Old Aug 3, 2007 | 04:55 PM
rexx78's Avatar
rexx78
What windows?
My 78 windshield trim came off without a special tool. I had to take the side windows off and remove trim screws for the side windows. The rear window trim needs the special tool.
Old Aug 3, 2007 | 05:03 PM
Me80C3's Avatar
Me80C3
Windshield and rear window.
What's the tool called, who would carry it, any parts store?
Old Aug 3, 2007 | 05:43 PM
Vettkeeper's Avatar
Vettkeeper
K-D Tools 2038 Window Moulding Remover for the rear trim
Old Aug 3, 2007 | 05:46 PM
Me80C3's Avatar
Me80C3
Thanks!
Old Aug 3, 2007 | 05:54 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
Take it easy with the plastic clips.
If they break you will need to take the rear glass out to replace them.
Old Aug 3, 2007 | 06:50 PM
Vettkeeper's Avatar
Vettkeeper
I am nowhere an expert on this, but I have replaced the rear window clips without removing the rear window. First if the window is still original it was installed with small plastic spacers to keep the window in the proper position, allowing for just enough clearance by trimming the plastic piece that locks the clip in place.
Old Aug 3, 2007 | 07:14 PM
Me80C3's Avatar
Me80C3
In the pic, am I looking at the underside of a piece of trim?
Old Aug 3, 2007 | 08:24 PM
Vettkeeper's Avatar
Vettkeeper
Yes the pic is of the rear window trim clip from the bottom side, on the top there is a plastic dowel that is pressed down to lock it into the place. I used a Dremel tool with a cutoff wheel and trimmed the bottom portion to make them fit without removing the window.
Old Aug 3, 2007 | 09:04 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Who told you that?
I replaced several of my clips without removing the rear glass, just pop of the damage clip with a screwdriver and take a small punch and knock the broken pin through to expose the clip hole.
New clips just snap in place, very easy and I never removed my glass
Old Aug 4, 2007 | 11:14 AM
Me80C3's Avatar
Me80C3
Thanks, the pics really help.
Now, for the windshield trim. I've done windshields on other cars and the trim presses into a groove in the rubber. Is this so with a Vette too?
To Chrome Window Trim Removal?
