Interior question,,
Old Aug 4, 2007 | 06:16 AM
RunningMan373's Avatar
RunningMan373
Default Interior question,,
Waht are those little Golf Tee shaped things that stick out of the lower dash, on either side, for?
Old Aug 4, 2007 | 06:22 AM
Ganey's Avatar
Ganey
To open & close the round vent next to it.
Old Aug 4, 2007 | 06:40 AM
RunningMan373
Pull/Push or Rotate?
Old Aug 4, 2007 | 06:46 AM
Ganey's Avatar
Ganey
Pull/Push
Old Aug 4, 2007 | 07:30 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Yup.
Old Aug 4, 2007 | 09:58 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Astro Ventilation...........
Old Aug 4, 2007 | 07:42 PM
rcread's Avatar
rcread
Better than air conditioning.
Not.
Old Aug 5, 2007 | 01:37 AM
vettebuyer6369's Avatar
vettebuyer6369
An owner's manual is your friend.
Old Aug 5, 2007 | 01:41 AM
RunningMan373
Mine don't push in/out, so they seemed to do nothing. Should get an owners manual and a AIM.
Old Aug 7, 2007 | 01:34 PM
iveym5's Avatar
iveym5
By the looks of your heater controls, I think your car has factory A/C. I have a '70 with A/C, and those ***** don't move at all. The owners manual isn't any help. It just says that they should pull out. I can't find those ***** referred to in the AIM either. I think that on A/C cars, they are just for looks. They just forgot to tell anybody that they don't do anything.
Can anyone else with an early 70's car with factory air confirm this?
Old Aug 7, 2007 | 02:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you don't have an original with the car, order a reproduction owner's manual. Lots of valuable goodies in the owner's manual. Order the assembly instruction manual for your year while you're at it.
iveym5 might be right. On AC cars the Astro-Ventilation vents are blocked off on the cowl. Cold AC air should blow through the vent *****.
Old Aug 7, 2007 | 03:23 PM
Hiteck's Avatar
Hiteck
I have a 74 with factory ac. The golf tees pull out to three different settings. There is a flap behind the silver ***** that moves when you pull the "golf tee". Mine is hard to open and close. The flap controls how much ac comes through the silver ball vent, at least on the passenger side. I've never looked at the driver side.
Old Aug 7, 2007 | 03:26 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
BUT, the controls do get rusty and then you can't push or pull to open/close the vent.
I added a Vintage Air system and now my are not functional at all, just there to fill the holes.
Old Aug 7, 2007 | 04:07 PM
VCuomo's Avatar
VCuomo
I can confirm that you are incorrect!
The ***** are supposed to push in and pull out to close/open the vents air restrictors - with or without A/C doesn't matter.
Old Aug 7, 2007 | 06:11 PM
iveym5's Avatar
iveym5
Yes, you are all correct!. I thought mine were supposed to pull out but they were already out. Then I pushed on them, and, after a little resistance, they went in. I got faked out because I was expecting to see a rod behind the **** when it was pulled out, sort of like the headlight switch when you pull it out.
Thanks for helping RunningMan373 and me!
To Interior question,,
