AC compressor O rings ??
Old Aug 5, 2007 | 08:06 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default AC compressor O rings ??
Here is a pic of the broken AC manifold that I replaced today on my 72 base 350. It blew COLD air for years. As I install the NEW manifold and hoses .... I can find no evidence of any O rings on this old piece AND none came with the new hose manifold.
LUCY says it should have rubber O rings!
Should it have O rings ????
I truely do not know .... Thanks........
Old Aug 5, 2007 | 08:22 PM
Durango_Boy's Avatar
Durango_Boy
When I took the A/C out of my car I remember it didn't have any O-rings either.
Old Aug 5, 2007 | 08:26 PM
72ls5fla's Avatar
72ls5fla
On the back of the compressor , where the manifold bolts into, there are two black thick looking o-rings embeddded into the compressor.
Bill
Old Aug 6, 2007 | 12:40 AM
RPOL68's Avatar
RPOL68
Default Sealing Washers
They are refered to as Sealing Washers and are about a buck a piece. They are a rubber/aluminum configuration. Should be able to get them at most parts stores behind the counter or at the dealer.
Old Aug 6, 2007 | 02:37 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
The O rings will fit on the compressor side, you will see a circular grove around both the high and low pressure ports, like that :
Hamad
Old Aug 6, 2007 | 03:29 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
AutoZone has the new green o-rings that are compatible with R134a.
Old Aug 6, 2007 | 08:01 AM
fotyfobravo
Thanks to all for the info and the pics.
I am all set now and Lucy is happy!
Fred
To AC compressor O rings ??
