72 AC system pressures ???
Old Aug 10, 2007 | 05:50 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default 72 AC system pressures ???
I finally installed my new AC hose on my 72 base coupe. Thankfully, I have R12 - - gauges and a vacuum pump. However I am not an AC expert.
Can anyone tell me the proper High and Low pressures I need for a proper charge on this system?
Thanks...........
Old Aug 10, 2007 | 09:41 PM
big_G's Avatar
big_G
Proper way is to fill by weight. That way you don't need to compensate readings based on temperature, etc. That being said....with 90* ambient, fan blowing on condenser....25 to 30 on low side, 200 on high side @ 1,500 rpm engine speed.
Old Aug 11, 2007 | 11:46 PM
ajrothm's Avatar
ajrothm
BIG G, what if you think you might have a leak? Do you top the system off based off of pressures? Not sure how much I have lost, if any, but I do know the front seal on my NEW compressor is slightly leaking oil and today I noticed I didn't have as much condensation on the ground(draining from evap core) as I usually do which leads me to believe, its not cooling as well. My vent temps were up about 3-5* today but today was the hottest its been yet so....not sure. I guess I need to take it to the shop for a check up but not sure if the shop owner will know the correct pressures for a fully charged/correctly operating system for R12.
Old Aug 12, 2007 | 01:06 AM
71 Green 454's Avatar
71 Green 454
I just go by the sight glass on the drier/receiver. When it clears up, I shut off the low side gauge and close the valve on the R12 jug.
To 72 AC system pressures ???
