Corvette Engineering Brake Kit
Just got my installation completed and car back on the road today. After bedding in, the system works great!! The kit was a straight forward install. I couldn't be happier.
Sounds like they work good.
if any? Can I use SS brake hoses I already have for my stock calipers or do you need to get ones from C.E. Also do you notice a difference in brake response and overall performance? Is there any noticable difference in handling with the reduction of unsprung weight? I am curious so I know what to expect with the kit. Thanks in advance and I would love to see some pics tooOriginally had planned to flush the lines and re-use, but many of the connections were frozen and bubba had rounded off many of them. Also, there was some pretty nasty sludge in the MC. So I decided to replace the works and have all new.
Your rear SS hoses will be reused, the fronts require a different hose that Keith includes in his kit.
Brake response is great. But to be fair, new or rebuilt stockers would probably be the same. The reduction in unsprung weight is significant and I did notice a ride improvement. Can't talk much to handling - havn't driven it a lot yet and my steering is rather sloppy (my next project
). For some reason, the steering is worse now than before the car was placed on jack stands.This kit's installation was straight forward. All my difficulties stemmed from issues on my car. Always got quick responses to my emails from Keith - customer support was great.
And to answer your question James, you may be able to reuse your front brake lines if they are the multi piece type.
the problem is the end that screws into the caliper. It's unique to the Corvette and I can't find an adaptor to save my life.
So I supply new lines in the kit.
