Air Conditioning-Need Help
Old Aug 12, 2007 | 01:40 PM
johnmisk's Avatar
johnmisk
Default Air Conditioning-Need Help
I have a 1971 SB with factory air. My recently developed problem is that the A/C stays on Max in all positions (that is OFF, MAX, NORM, and BI-LEVEL), the compressor only stops truning in VENT, HEATER, and DE-ICE. I took the shift plate off and the vacuum tubing connection to the switch appears to be in good condition. I'm clueless as to where to look to locate the problem. Can anyone tell me how to trouble shoot or otherwise point me in the right direction to fix this problem. Thanks, John
Old Aug 12, 2007 | 02:16 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
did you check the side contacts which are controlled by the sliding wheel? theres one contact that should disconnect the a/c power when in off position, maybe its stuck short.
Old Aug 12, 2007 | 02:21 PM
SIXFOOTER's Avatar
SIXFOOTER
Isn't there a pressure switch under the hood that cyclles the compressor?
Old Aug 12, 2007 | 02:34 PM
johnmisk's Avatar
johnmisk
Thank you! It was the side switch as you described. It seems to be working now after I played with it a bit.
To Air Conditioning-Need Help
