1968 Ventelation System
Old Aug 14, 2007 | 02:11 PM
BritGreen68's Avatar
BritGreen68
Default 1968 Ventelation System
I have been looking for pictures and diagrams of how ventelation system hooks up for a 1968 (late...built in August 68). I pulled the interior and dash pieces out to find no plumming for the astro ventelation or cabling/vacuum. My car has AC so am looking for what what opens the ventelation for the fresh air. Is it the same setup as a 69...vacuum? I appreciate your help.
Old Aug 14, 2007 | 02:25 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Try an AIM.....what is the build date or VIN on your car?
Old Aug 14, 2007 | 03:10 PM
BritGreen68
My VIN is 194378S427089
Old Aug 14, 2007 | 03:16 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
thanks, this is off the subject, but what is the build date in the door jamb?.....Also, back to your original question, do you have an assembly manual? Thet's where I would start, Semper Fi, thanks, john
Old Aug 14, 2007 | 03:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. You need the AIM. AC cars have the stock Astro-Ventilation holes blocked off. The only operable one is behind the right kick panel. Vent ***** in the dash will blow cold air with the AC on and outside air when Vent is selected.
BritGreen68
I will look at the build date in the door when I go home tonight. Is the build date on the same tag as the interior-exterior tag or where should I look.
I do have a manual but doesn't show exacts...so, you were in the Marines? Joel
Old Aug 14, 2007 | 03:57 PM
Easy Mike's Avatar
Easy Mike
...Is the build date on the same tag as the interior-exterior tag or where should I look....
Yep. Upper righthand corner of the trim tag. You should find an M date. The last '68 was assembled the week of 8/16/68 and she was #28,566. 27,089 is is only 1477 shy of the end of production.
Old Aug 14, 2007 | 04:06 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
yes build date is on the tage, for Aug 68 should have the letter "m" followed by a #..its off the subject and I apologize, but I've been looking for a picture of a car built arounf Aug 15th 68..........yes, I was in the USMC, enlisted prior to college, Parris Island 1986., Engineers, Reserve.
Old Aug 14, 2007 | 04:54 PM
BritGreen68
Here is a site with pics of my car when I bought it last summer. http://mustangenthusiasts.net/1968_corvette.htm The guy told me it had a 350 in it but turned out to be 307 out of a 69-73 whatever. Other than that some things might be wrong like the driver door mirror and the radiator overflow. I bought a 427 390/400hp block built in April 68. The car is primer white right now and the interior is out. Building up my parts bin to start working on the car.
Old Aug 14, 2007 | 07:39 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
If you have an AC original car, then you dont have astro ventillation, the AV was for Non AC cars only
Old Aug 14, 2007 | 08:57 PM
BritGreen68
Ok, I looked up my tag. It says "L29"...so this would mean July 29th? Almost an August car.
I was looking at some other replies...If I have ac then I don't have astro ventilation. If I have my ac off but want ventilation then the lever in my center console would open the side doors (buy the kick/speaker panel) via vacuum instead of a mechanical lever in the center console. It's starting to make sense. So, wouldn't this be like the 69 design?
Old Aug 14, 2007 | 09:11 PM
DARROW's Avatar
DARROW
ARE YOU SURE ABOUT THAT?
Old Aug 14, 2007 | 09:41 PM
BritGreen68
Darrow, that's why I'm here. My car is missing some under dash pluming so am trying to figure out what I'm missing and can not find proper documentation with my shop manual. There are fresh air intakes on the left and right side of the car (by the kick/speaker panel) which have to open and close somehow even though it comes with ac?
Old Aug 14, 2007 | 10:16 PM
DARROW's Avatar
DARROW
bretgreen68
My post ( are you sure ) was not to you I have a 74 with astro vent written on the windows but I have factory air and the venting is only on the passinger side but is channeled to both sides.
have you removed the kick panels? on mine the drivers side is blank. Everthing air, vent , heater works from the passenger side my manual shows this. but I don't know about yours .
If you have a/c I think it might be the same. If your questings come from heat in the cab then thats another problem.
Darrow
Old Aug 14, 2007 | 10:32 PM
DARROW's Avatar
DARROW
Do you have the original assembly manual?
I have looked in several catalogs and can not find a drawing on duct work........
Old Aug 15, 2007 | 01:35 AM
BritGreen68
Originally Posted by DARROW
bretgreen68
Darrow
Darrow, I looked in my 1968 Service Manual and it shows a "behind" view of the dash. It does show how the left and right dash vents go into the ac ducting so, I'm good there. My other issue is how does the fresh air ducting hook up. I just took these pictures tonight...see what you think;
Passenger side fresh air inlet area. http://www.mustangenthusiasts.net/In...irvent_002.jpg (click on the picture to enlarge)
I took the door out that would swivel allowing air in and out of the car. Also, above is some king of duct with a spung in it. Don't know what that's about.
Drivers side fresh air inlet http://www.mustangenthusiasts.net/In...irvent_002.jpg (click on the picture to enlarge)
The air inlet door is still there. Hope these pictures give you a better visual.
http://www.mustangenthusiasts.net/1968_corvette.htm
Old Aug 15, 2007 | 01:48 AM
Manuel Azevedo's Avatar
Manuel Azevedo
yes this is true, AC 68 cars do not have Astro Ventelation. Mine is a very late 68 vin 28277 build date Augest 14th and has the Astro Ventelation on the side windows but no Astro Ventelation as others have said, the vents are blocked off except the one on the right side kick panel.
To 1968 Ventelation System
Old Aug 15, 2007 | 07:44 AM
sweethence's Avatar
sweethence
Very sure
Old Aug 15, 2007 | 09:04 AM
Easy Mike's Avatar
Easy Mike
We're stumbling over semantics here. "Astro-Ventilation" is generic and is the term GM came up with for the fresh air system on the C3s. Technically, all 68-74s have Astro-Ventilation.
For non-AC cars, there are two ducts on each side of the cowl, upper and lower. Uppers route outside air to the vent ***** in the dash. Lowers route outside air through the kick panel vents by way of the VENT ***** on the console. Sliding the VENT **** on the console manually opens or closes the kick panel vents through a Bowden cable. Some years have a **** on the dash which opens or closes air flow through the dash *****. '68s do not have these.
Upper to dash vent *****. Lower to kick panel door.
AC cars have three of the cowl outlets blocked off. Right side only kick panel door opens and closes with vacuum (no Bowden cable) in conjuction with a flapper door under the right fender at the top; cold air through the dash ***** with AC on; outside air through the kick panel and dash ***** when the system is off of AC and on vent.
Right side AC car. Kick panel vent vacuum operated. Flapper door covers the upper cowl vent.
There is also an Astro-Ventilation vent on the rear bulkhead. Cabin air is supposed to vent out of the car through this exit. On some AC cars, the bulkhead vent is also vacuum operated and is either open or closed depending upon AC or vent.
Note bulkhead Astro-Ventilation vent just above the tape measure to the left of the rear deck vents.
Old Aug 15, 2007 | 11:38 AM
Manuel Azevedo
This whole talk was about the system on a 68, and they do not have Astro Ventelation with AC. They also do not use the rear vents either as all they have is a water drain connection on them and no air exit to them at all on AC cars. But I think this subject has been beat to death.
