Vacuum Switch
Old Aug 15, 2007 | 08:38 PM
sly vette's Avatar
sly vette
Default Vacuum Switch
Does any one make a vacuum switch? As in something that I can substitute for the switch at the headlight switch?
I have had 3 different headlight switches go bad 'cause they developed a vacuum leak. I have the old override sw. that I could use, correct?
Old Aug 15, 2007 | 09:38 PM
...Roger...'s Avatar
...Roger...
You can use one of the pulldown or bypass valves they are exactly the same as the headlight vacuum valve.Just make sure the hose that goes to the relays is on the port opposite the handle or ****.Below is how it should be hooked up.
IMG]
Old Aug 15, 2007 | 10:11 PM
...Roger...
Old Aug 16, 2007 | 05:51 AM
sly vette's Avatar
sly vette
Thanks!!!
Old Aug 16, 2007 | 09:24 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Thanks!!!
you could also jury rig a second wiper solenoid switch with leads from the headlight swicth if you felt like doing some splicing
To Vacuum Switch
