#4 body mount reinforcement question
I will be replacing my #4 body mounts soon. My question is the reinforcements on the body itself, is there an adhesive that goes in there? I have looked in the AIM but that doesnt tell me much.
I remember in a previous post someone said use polyurethane adhesive I think.
Just need clarification on this.
Thanks for any advice.
Peace.
I would then lift the body with a piece of plywood under the battery compartment.
Go slow and you don't need to lift much.
For later rubber mounts, there is a little more space in there.
It is possible to lift on the rear body and flex enough to get the reinforcement out.
I don't recommend this unless the other mounts are a can of worms.
I used the polyurethane adhesive to seal and adhere the reinforcement.
I would not use silicone. It tends to peel eventually ... urethane for longevity.
Don't like the idea of getting the adhesive at Home Depot ? ....
use a urethane windshield adhesive, available at most GOOD auto stores (3M window weld).
loose or removed. The bumpers bolt the fiberglass directly to the frame.
A plastic rear bumper may have similar connections to loosen.
My 75 cam ewith a fiberglass rear bumper mcover, so there was no
connection from bumper to frame, since the supports need to be removed
to install the glass cover.
There is one or two rivets in the back that you can't see without drilling a hole in the splash apron. The rivets are usually corroded enough that they will break with a little prying. If not, a rasp file or chizel will make fast work of the rivet heads and the support should be free. I leave that rivet out on installation.
