Low fuel ?
Old Aug 16, 2007 | 09:31 PM
RONZ-C-3's Avatar
RONZ-C-3
Cruising
Default Low fuel ?
Half of a tank of gas but low fuel light is on
any ideas?
Old Aug 16, 2007 | 09:37 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Does it go out when the tank is full?
My guess is the sender, I would start with that.
Here's schematic to show you how the light is tied into the wiring.....
Old Aug 16, 2007 | 09:43 PM
RONZ-C-3's Avatar
RONZ-C-3
Cruising
No it gets britter as it gets filled
Ihad the cluster out in the winter Iwounder if something did not go back together correctly.
Old Aug 17, 2007 | 12:20 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Is the little 1" square low fuel circuit board installed with the light bulb?
Old Aug 17, 2007 | 08:07 AM
1982CorvetteDude
I though that the little circuit board might be missing myself, but he says it goes out after the tank is full.
My car was missing the board when I bought it and it had a regular bulb and socket in it's place......it stayed on no matter how full or low the tank was.
Old Aug 17, 2007 | 08:34 AM
...Roger...'s Avatar
...Roger...
Sounds like its working in reverse for some reason.Do this little test in this pic.Put board side down - looking down at bulb.Make sure your circuit board module works like described.The light is supposed to come on with almost NO resitance-same as EMPTY on gage.
EDIT-Where it says pos and neg to batt. -that is pos to pos and neg to neg ---(not both on pos)
To Low fuel ?
