Paint opinions needed
Old Aug 17, 2007 | 05:39 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Paint opinions needed
My 73 BB coupe is at the shop being stripped as we speak. My plan is to re-paint the car it's original metallic yellow with a Baldwin Motion theme striping since I added a L-88 style hood. I know the metallic yellow is not a "cool" color but it is an original #'s car. (motor is crated and a built 454 replaced) What think you guys??
Old Aug 17, 2007 | 06:10 PM
weimer20's Avatar
weimer20
2 points of view on this. If you want to keep the car totally original, go with the original color and scheme. 2nd point is this. The car is not original factory now as there is a different engine in it. True, it would be infinitely easier to replace the engine with the original one as opposed to doing that AND repainting to return the car to "original" status. Sooo, how long do you intend to keep the car and how much do you like the original color? If you want a different color and you plan on keeping the car for some time, paint it the color you really like and simply plan on having to repaint in the future if going back to "original" color assuming that this impacts the resale value significantly.
cal camara's Avatar
cal camara
Default Wish mine was yellow
I have a 72 that is black. I want to repaint it original. The original color is Ontario Orange. Yuck I would stay original. Yellow is better than Ontario Orange, even basic orange would be better. I have the color problem , yellow is OK, go original.
cal
Old Aug 17, 2007 | 06:25 PM
Jims79's Avatar
Jims79
I say paint it what ever color you like best & enjoy it. Let the next guy repaint it yellow.
Old Aug 17, 2007 | 06:46 PM
John 65's Avatar
John 65
I had something like that.
Old Aug 17, 2007 | 07:13 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I don't think thats exactly what he had in mind.
I think its a great idea Brent.
Old Aug 17, 2007 | 07:16 PM
John 65's Avatar
John 65
LOL, I hope it's not.
Old Aug 17, 2007 | 08:50 PM
72LS1Vette's Avatar
72LS1Vette
cal
OK. If you weren't 3,000 miles away I'd come over and smack you. Check out some good pics or paint samples of Ontario Orange. It is a metallic finish that looks more like a gold/bronze color in the light. I was a bit put off as I drove up to the house that had what is now my 72 and seeing the orange color, but it really does look great in the sunlight. When I repaint the car I will probably go for a more modern base/clear version of Orange but I'm straying a little from NCRS with the LS1 anyway.
Rick B.
Old Aug 17, 2007 | 09:00 PM
cal camara's Avatar
cal camara
Default Ontario orange
Well maybe I over did it a little on the Ontario Orange. I like original colors, not only because it adds some to the value as a rule but it makes it easy to decide what color to paint the car. I, at first liked Ontario Orange in pictures, until I noticed the color on a car, it had no snap. The owner said he had a hard time selling his car because it was orange, he said keep mine black. I still may go original Orange, maybe add a more zip to the color.
Old Aug 17, 2007 | 09:04 PM
vettebuyer6369's Avatar
vettebuyer6369
I'm not following your logic. It has an L88 hood and you are adding a custom stripe design, but you are using a base of the original color because it's numbers matching. (or would be when you reinstall the correct motor)
Seems to me a custom hood under the stock color with a custom stripng scheme isn't any more stock than painting it purple, ya know?
If you like the metallic yellow, fine use it. But if you are using it because its stock and the numbers matching motor is in a box, but you would prefer a different base color with your Motion custom design, then use the color(s) you like.
Old Aug 17, 2007 | 09:24 PM
cal camara's Avatar
cal camara
Default color
If you plan on keeping her, and you like a specific color by all means paint it your way. I have several cars some original some not. When I not can really decide I default to original. Sometimes an original color keeps the car looking period. Sometimes painting a classic a unoriginal color makes them look odd. You have to decide who you are painting it for, you, us or someone else. Someone will like yellow?
cal
Old Aug 17, 2007 | 09:50 PM
dbeall1968's Avatar
dbeall1968
Default That's one FUGLY Vet!
Man! That's Ugly! What was that guy thinking? Narcotics should be kept away from paint shops. I'm glad a caring owner has it now. Got any new pics?
Old Aug 17, 2007 | 10:03 PM
Deron's Avatar
Deron
I had a similar dilemma deciding to paint my 73 back to it's original green. I'm glad I did. It get lots of attention, and no one can believe that it is an original factory color. I like the metallic yellow very Similar to war bonnet yellow if not the same. And I'm sure you'll be the only guy around with a vett that color.
Most vetts including mine were painted red, white, or black at one time,and no offense to others but i think thats boring. Factory colors were cool back then, and are even cooler now
Unless it was green
Old Aug 17, 2007 | 10:25 PM
MI-CORVETTE's Avatar
MI-CORVETTE
farmer, make sure your shop is planning to use a polyester type primer (or gelcoat) after they strip it. Many guys think they can put regular primer that contains alot of solvent directly over a stripped vette. The problem comes down the road when the solvent that has permeated the glass comes back in the form of small bubbles through the paint. The polyester has minimal solvent and creates a barrier. PPG MP243 can be found at any PPG distributor and will work great. Good luck...
Old Aug 17, 2007 | 10:37 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Thanks for all the great replies. I too like the odd colors.
Old Aug 17, 2007 | 10:39 PM
cal camara's Avatar
cal camara
Default And
So. What color?
cal
Old Aug 17, 2007 | 10:47 PM
72LS1Vette's Avatar
72LS1Vette
Seems like Orange is coming back into style. Lamborghini Orange is pretty and I saw a Saturn SUV the other day that was a shade of Orange. I think the original O.O. color depends a lot on how it was taken care of. The paint is a 1-stage so if it gets oxidized it probably looks pretty dull. The paint on my car is in no way pristine - more like a 20-footer, but at least some of the body looks good when cleaned and waxed. Modern paints are so superior in color that you can find an awesome Orange that will at least have the spirit of the original.
Rick B.
Old Aug 17, 2007 | 10:57 PM
opus1111's Avatar
opus1111
That's what I was thinking. I just wish I had a car like yours!
Old Aug 18, 2007 | 04:08 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
When I swapped the stock hood on my SA for the long L88, here's what we came up with...
BTW, if you don't pick a color you really like, you're more likely to be trading it for something else that strikes you.
To Paint opinions needed
