Electrical Problem???
Old Aug 20, 2007 | 10:59 AM
tjc69's Avatar
tjc69
3rd Gear
Default Electrical Problem???
So here is the deal....i have a '69 and if i leave the battery connected it will drain it and my brake lights wont work along with my right turning signal....i have been told it might be a problem with the ignition switch...anyone have an idea or had/have the same problem?????
Old Aug 20, 2007 | 11:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Obviously, you have a drain on the battery. Could be a bad ignition switch; could also be something simple, like the glove box lamp staying on; courtesy lights left on, etc.
A battery disconnect switch will stop the power drain while she's parked, but won't help find the source of the drain.
