Wheel and tire package.
Old Aug 20, 2007 | 12:42 PM
Block_Head's Avatar
Block_Head
Default Wheel and tire package.
I had found a good deal on some c6 corvette tires with almost no miles, and the rear tires are huge. The fronts were 245 I think and the rear were 280 maybe.
If I were to buy the tires and find rims later would they all fit and would i have problems with rubbing?
I did search this but I found so many threads about this that I was just confusing myself.
Old Aug 20, 2007 | 01:43 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Something in the back of my mind tells me C6 tires are run flats and are meant to be used with the LTPW system. They are also probably uni-directional.
Old Aug 20, 2007 | 01:49 PM
Block_Head's Avatar
Block_Head
So they may not even work on standard rims?
I'd be okay with them being directional.
Old Aug 20, 2007 | 02:20 PM
Kev99's Avatar
Kev99
They would work on normal rims, you would just need to get some sensors that let you know if the tires are low on air. I do not think the C6 sensors would work, because they are tied to the electronics in the car. But you can get aftermarket sensors. I could not tell you as far as fit goes. I have to get a c3, before I worry about wheel and tires
To Wheel and tire package.
