Front Bumper Cover Removal
I was in the process of removing the frame extensions on my 78 SA and noticed that in order to get to the bolt in the front of the extension that I would have to remove my front bumper cover. Well the first two bolts that i tried after soaking in PB Blaster snapped off pretty quickly. Just to make sure before I went any further I was thinking that these bolts were part of a brace that could be replaced, correct? I would hate to think that these bolts are attached to the bumper cover and that the whole bumper cover would have to be replaced if i snapped the bolts off.
I looked through some of the sites like Zip Corvette and they show front bumper stainless steel retainer sets. I am assuming that these are what i would use to replace the snapped rusty bolts.
I am hoping I am not biting off more than I can chew since I have read in some parts of the forum that taking off the front bumper cover is a mistake. Let me know if anyone has any tips or advice or if there do's and dont's to this project.
After the front bumper cover is removed anyone have any tips on the temporary storage of it so that I can help prevent warping or cracking?
The top has three sections, left/right/center 28997-28995-28996, and there is a curved section on either end 28998-29997. When I removed my front bumper a few years back, EVERY SINGLE BOLT snapped off. I managed to salvage the outer retainers by cleaning, grinding, POR15-ing, and welded small diameter 1 1/2" bolts in the original holes so they'd still work like they're supposed to. My top/middle sections were too far gone (rust) so I made my own with 7/16x1/8 lengths of metal (about 5 bucks from the metal store), drilled holes in the right place and welded the same little bolts. This all worked perfectly, and the bumper is attached now as good as new. the separate little retainer "sets" that the vendors sell might not work as well with a flexible original (rubber) bumper, they're meant for fiberglass ones I believe.
