sealant question
Old Aug 31, 2007 | 05:09 PM
smon's Avatar
smon
Default sealant question
75 vette, water leaks in from the windshield wiper area.
what do i need to use to seal that area?
Old Aug 31, 2007 | 05:14 PM
Durango_Boy's Avatar
Durango_Boy
You may have a larger problem.
The birdcage, or structure that makes up the cabin of the car is all metal. As water leaks through and around it it starts to rust from within, and it can happen without you ever seeing it.
You need to remove the A-pillar trim, T-top trim, and kick panels and inspect for rust. Look as deep and as far as you can in every section of that structure looking for rust.
If you see some, where the rot has penetrated the metal, you have found a serious problem.
If your birdcage is free or rot then it really may just be a bad windshield seal.
Old Sep 3, 2007 | 10:56 AM
75 Hot One's Avatar
75 Hot One
Mine has leaked since new. I took it back to the dealer several times but it was never repaired properly & still leaks. One of my long term projects is to take the window trim apart as durangoboy suggests and do a proper repair.
Looking back on the Corvette history with the benefit of hindsight and considering the fabrication quality of cars today, it amazes me (as it did then) that GM turned out the crap it did during the C3 years. The service at that time was as bad or worse. Although GM is in serious difficulty these days, the amazing thing is that they're in business at all.
To sealant question
