I want to get American racing torq-thrust wheels for my 68. I will be getting offset trailing arms and the dual mount spring. I would like 18X8 on the front and 18X10 on the rear. Will this setup realistically work, any rubbing etc? What size tires as well as back spacing do I need? Thanks for all the input!
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
C3 backspacing is 4 in. I have 17 x 8 with 4 in BS on the front of mine and 18 x 9.5 with 5 in. BS on the back with stock trailing arms and 285/40/18 rubber on the back. Car handles real good now with ZR rated Toyo T1R tires.
Did you have to relocate the e-brake cable bracket or the remove the rear sway for for the 9.5'' rims to fit in the rear? Any other things to lookout for with the wider rear tire?
Ok so the standard backspacing is 4” and for 18X10 I need 5.5”. To me that mean 1.5” of the extra 2” goes into the car and the other 0.5” goes out. I was looking at my vette this weekend and it does not look like there is space for the wheel and tire to stick out ½” inch more. One possibility is my current wheels could be 3.5” backspacing. I currently have wheel vintiques rally’s 16X8. I will have to measure.
I know...no-one asked but in my humble opinion putting oversize rims with little bitty sidewall tires makes me think some-one whats to Rice-r-ize the look of a CLASSIC C-3.
Everyone is entitled to the own opinion... Personally, its tough for me to choose between the 18's and the 15's...
As far as rice r ize goes... I think that is impossible to do to a C3 its too AMERICAN
I used to think the same thing, times change, and try and catch me around a corner with S rated tires compared to my little bitty sidewall ZR rated ultra performance tires
That's very true
But then again IF I was to be chasing you around corners a 40 year old car would not be my vehicle of choice either!
The kind of rubber you mount on the rims can make a HUGE difference. I need to upgrade my rims/tires. 225/70/15 sucks. It does look classic; but handles classic too.
And as we all know they don't make performance tires on 15" rims for us.
My civic daily driver with Z rated rubber will out handle the corvette easily. That wasn't the case until I got the new tires on the civic.
I think with the classic wheels being made in bigger sizes the bigger wheels look better on the older c-3's. The hard nose sharks look nice with vintage style wheels.
I figure I only live once which is too short a time to baby my car all the time. I like it to look like a show car and drive it like a rental.
Tires you use is only part of the game, if good rubber was enough to transform a bad handling car into a hillclimb champion...
but it's not enough, it is just part of a whole with many variables.
weight and its distribution, chassis design, steering, unsprung weights, suspensions (with all its components), tires...
each one of them that is uprated contributes to better the handling but not to transform the way a car drives.
When I took the mighty S rated BFG's off and put on the ZR rated Toyo T1R's and went around the first corner it was amazing.
It was like the car was glued to the pavement. I thought to myself so this is what it feels like to go around a corner in a sports car, finally after 10 years
