Is my distributor original?
Old Aug 31, 2007 | 07:11 PM
7t5's Avatar
7t5
St. Jude Donor '14
Default Is my distributor original?
Can anyone tell me where the numbers are on the distributor in order to tell if it is original? So far I have determined the carb and alternator are correct. BTW, It is a 1975.
Old Aug 31, 2007 | 07:58 PM
BKarol's Avatar
BKarol
http://www.corvette-world.com/corvet...stributors.php
http://corvetteactioncenter.com/specs/c3/1975/75id.html
If you need to check the number
Old Aug 31, 2007 | 09:47 PM
7t5's Avatar
7t5
St. Jude Donor '14
Thanks, but I have the # from my black book. I was wondering where on the dist. the number would be located.
Old Aug 31, 2007 | 11:24 PM
crazywelder's Avatar
crazywelder
Here you go. This is the correct number for a '75 distributor 1112888. With a build date of 7/10/74.
Old Sep 1, 2007 | 08:17 AM
7t5's Avatar
7t5
St. Jude Donor '14
Thanks! Nice car. Did you have your dist. rebuilt? Just curious why it was out.
Old Sep 1, 2007 | 10:29 AM
crazywelder
Thank you. When I swapped engines a few years back I installed an MSD HEI that I had. The original engine is stored away.
To Is my distributor original?
