how heavy
Old Sep 1, 2007 | 12:30 AM
gregsno's Avatar
gregsno
Default how heavy
how much does a 1976 body weigh
Old Sep 1, 2007 | 02:54 AM
vettebuyer6369's Avatar
vettebuyer6369
curb weight 3541 lbs.
Old Sep 1, 2007 | 02:57 AM
SEVNT6's Avatar
SEVNT6
Or about 541 lbs to much the way I've always looked at it............
Old Sep 1, 2007 | 03:02 AM
panic's Avatar
panic
...far too much...
if you dont drop its weight well under 3.000lbs it will only be a 'sportcar shower' and not a real sportcar performer.
And now i better go to the beach
Old Sep 1, 2007 | 10:00 AM
gregsno's Avatar
gregsno
well i was wondering if my celing rafters will support the weight when i lift the body from the frame???????????
Carl Granquist's Avatar
Carl Granquist
Do you mean the entire car, or just the body? I'm guessing the fiberglass body only weighs a few hundred pounds. The dolly design folks use to store it during a frame-off really doesn't look sturdy enough to support 3,500 pounds.
Old Sep 1, 2007 | 10:18 AM
Attfay Elleybay's Avatar
Attfay Elleybay
I think he's talking about just the fiberglass body. My guess would be about 500lbs. But that's a WAG.
Old Sep 1, 2007 | 01:08 PM
VetteThunder1's Avatar
VetteThunder1
I wouldn't use the rafters, just in case.
I built a gantry out of some 4x4's and it wasn't a problems total cost in wood and lag screws was like $40 or so. The width I used for the cross beam on my gantry was 6feet. Worked very well. But I would suggest a hoist or winch as opposed to a come-along like I used, that made things a little difficult when I was lowering the body.
It also depends on if the body has been stripped, interior, wiring, glass, doors etc., etc.,
I would guess that my 68 body weighs in the neighborhood of 300 to 400 pounds, I can easily lift one side by myself.
Good luck!
My gantry.
Old Sep 1, 2007 | 07:47 PM
gregsno's Avatar
gregsno
yea I removed doors, glass, hood, t-tops, all interior. Thanks for yuor responses it just gives my a little more nerve and assurance which i need cause I want to be as careful as I can so I can eliminate as many problems as I can cause Murphys law is always in play. thanks alot guys heres to ya
To how heavy
