Missing reverse lights on a '68?
Old Sep 1, 2007 | 05:13 PM
Sihler's Avatar
Sihler
Default Missing reverse lights on a '68?
My '68 has no reverse lights, I assume somewhere along the line an owner removed them and filled the space in. I was looking through a book that I have and noticed that the '68's in it were also missing the reverse lights. Was removing the reverse lights a popular thing to do on these cars?
Old Sep 1, 2007 | 05:44 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I believe the '68 reverse lights would have been in the lower panel on each side of the license plate, and weren't placed in the inner tail light fixtures until '69. If I run across a pic in the next day or two, I'll post one.
Old Sep 1, 2007 | 05:48 PM
SEVNT6's Avatar
SEVNT6
In '69 they went with back-up lights in the lens.......
Old Sep 1, 2007 | 06:08 PM
TheSkunkWorks
'68 only location...
I think I might do this on my SA some day, since I have 4 red bubbles... Na!
Old Sep 1, 2007 | 06:22 PM
rihwoods's Avatar
rihwoods
My 69...Lord of The Rings....
Old Sep 1, 2007 | 06:29 PM
Nvts's Avatar
Nvts
Mine are there, they just don't work yet
Old Sep 1, 2007 | 08:04 PM
Ironcross's Avatar
Ironcross
There is also a switch on the trans to operate the back up lights.
Old Sep 1, 2007 | 08:08 PM
Sihler's Avatar
Sihler
Oh, I know well where they should be, but my rear was either filled in or replaced with a '69+ panel, I was just wondering if it was common to remove them, it does look cleaner without, but I would hate to get hit while backing out of a space, also, it would never pass VA safety inspections without. I looked and the wiring for the lights is there.
Old Sep 1, 2007 | 09:48 PM
C3 4ME's Avatar
C3 4ME
You could register your car here in VA as an antique and it would never have to go through inspection again. My 79 is registered that way. I have non functional reverse lights on mine. Someone removed the switch and all the wiring to the switch. Look on DMV's website for the specfic restrictions for registering a car with antique plates or year of manufacture plates.
Old Sep 1, 2007 | 10:11 PM
Sihler's Avatar
Sihler
I didn't realize that it wouldn't have to pass safety inspections with antique tags, I just might have to do that.
Old Sep 1, 2007 | 10:44 PM
PRNDL's Avatar
PRNDL
I seriously doubt that anyone ever willingly removed their 68 backup lights just to change the look. I would guess that damaged panels were frequently replaced with 69 panels that did not have the backup lights.
Old Sep 2, 2007 | 12:58 AM
TheSkunkWorks
If you drive your shark a lot, the antique tag could hinder your enjoyment should your local constabulary be sticklers.
...but, then everyone's not like that. The last time my not-even-close-to-original '78 went thru an inspection, the guys just gave a grin and passed me right thru every station. One of them even suggested I put the car in third or forth before doing the e-brake test. And, I don't even have back up lights either.
Old Sep 2, 2007 | 12:08 PM
Sihler's Avatar
Sihler
I wish, here in VA, I had a guy fail my '97 because there was visible brake fluid around the master cylinder lid. VA sucks!!
Old Aug 8, 2018 | 10:40 AM
scotish44's Avatar
scotish44
The reverse lights on my '68 are also missing. I was baffled about it. The only explanation I can think of is that someone replaced the lower rear panels with '69 panels? Any other info on this would be great
Old Aug 8, 2018 | 06:29 PM
caskiguy's Avatar
caskiguy
Here you go.
1968 unrestored rear
Old Aug 8, 2018 | 06:58 PM
derekderek's Avatar
derekderek
Quickie fix. https://www.ebay.com/p/Fits-a-6-by-1...ff06c16&chn=ps
Old Aug 8, 2018 | 07:15 PM
ronarndt's Avatar
ronarndt
When I got my 68 convert three years ago, the PO had fiberglassed over the reverse lights and painted the panel. The light sockets were still there on the back, so I carefully cut out the fiberglass and returned the reverse lights to their original operating condition. Not sure why the PO did this, since he did not change the inner brake/tail light to the 1969 style with back up lights. Work in progress and finished job shown here.
To Missing reverse lights on a '68?
Old Aug 8, 2018 | 07:25 PM
caskiguy's Avatar
caskiguy
Nice job.
Old Aug 8, 2018 | 07:28 PM
Corey_68's Avatar
Corey_68
MUCH better
Old Aug 8, 2018 | 07:58 PM
theandies's Avatar
theandies
That's on my mods list too. It's part of my two brake lights per side as the '68's have. I like that a lot better and always wondered why GM went to those ugly (IMO) backup lights in the inner lens.
The only problem with using '68 parts as this is one of those '68 only things and the parts are pricey. There are nice, small rectangle aftermarket housing assemblies out there that will replicate that look.
