Help removing rusted bolts...
Old Sep 6, 2007 | 02:29 PM
tbcbi's Avatar
tbcbi
Default Help removing rusted bolts...
I'm trying to replace some exhust parts on an '82. Tried everything on rusted bolts. nothing is working. Anyone have any ideas??? Thanks.
Old Sep 6, 2007 | 02:34 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
I haven't tried this stuff, but I've been told that it's much better than anything you can buy at the autoparts stores.
http://www.kanolabs.com/
Old Sep 6, 2007 | 02:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What have you used? Have you tried heat?
Old Sep 6, 2007 | 02:40 PM
Green73's Avatar
Green73
If your actually replacing exhaust, the easy thing to do is use the good old hacksaw and cut the pipes. You could also use a cut off wheel and cut some of the old exhaust clamps off. If your dealing with bolts to the manifolds, you'll need to take a different approach. You're going to have to be more specific as to what the problem is. Are you rounding off bolts or just can't turn them. Unable to turn means you'll either have to buy a gym membership and get stronger... or get more leverage. Use a half inch ratchet and a "cheater bar" or a breaker bar. Assuming you've PB blasted the bolts and its still not turning or the heads are rounding, you may need a torch.
Old Sep 6, 2007 | 02:54 PM
Scatterbrain's Avatar
Scatterbrain
PB blaster worked really well on some seized bolts on my car. I just sprayed it once a day every morning till the weekend came and I could try removing them.
Old Sep 6, 2007 | 03:58 PM
dannyman's Avatar
dannyman
PB Blaster 24 hrs then hit them with an impact wrench.
Old Sep 6, 2007 | 04:25 PM
jdp6000's Avatar
jdp6000
Another product called "Liquid Wrench" works pretty good too.
Jim
Old Sep 6, 2007 | 04:44 PM
ROBMERRILL's Avatar
ROBMERRILL
I have used a heat gun and its has worked just fine on rust bolts/nuts. Just be careful not to burn anything else or light your car on fire!
chevy69's Avatar
chevy69
St. Jude Donor '08
sawzall for rusty exhaust
it's all getting replaced anyway, right?
Old Sep 6, 2007 | 06:08 PM
Nvts's Avatar
Nvts
I have recently removed dozens of bolts from a '68 car from WI. You won't find much more rust than that, without extreme situations. Most of the time, all I needed days worth of PB blaster soaking, and normally a propane torch. I got almost every single nut off of the bolts that I tried. More of an issue than that was getting the bolt out of the bushings/sleeves or whatnot. The right sized tool, heat, penetrating fluid, and leverage should take care of 99% of the bolts. When you get those other ones, you have to saw it or grind it.
Old Sep 6, 2007 | 07:08 PM
72LS1Vette's Avatar
72LS1Vette
If what you are trying to remove is easily replaced just saw it off. If it is something that you need to preserve PB Blaster will usually free it up if you spray it on for several days. Don't force the nuts when you remove them - once they start to move keep turning them clockwise and counter-clockwise a bit at a time until they unscrew.
Some parts may be so rusted that nothing you do will prevent them from breaking.
Rick B.
Old Sep 6, 2007 | 08:29 PM
chuck d's Avatar
chuck d
I agree, we have used Kroil at the airline I work at for the past thirty five years. It works!
Old Sep 6, 2007 | 10:09 PM
stock76's Avatar
stock76
Worked for me too. Soak em for a few days in PB blaster. Every one came loose. The problem I had was separating the exhaust pipes. A Porter Cable sawsall took care of that.
Old Sep 6, 2007 | 11:59 PM
kg4ajk's Avatar
kg4ajk
I have had pretty good luck with Breakfree.Same stuff i use on my rifles.squirt some on let it set several hours and put some more on , let it set overnight then try.Bought a gallon 10 years ago, will never run out. But as 72LS1Vette said; Some parts may be so rusted that nothing you do will prevent them from breaking.
Old Sep 7, 2007 | 12:41 AM
ffas23's Avatar
ffas23
PB Blaster is the best out there to loosen up nuts and bolts. Other then that a air driven cut-off wheel works great on exhaust clamps and pipe. An electric Sawzall also works great. Also a handheld grinder will do the trick but for soaking PB Blaster is the way to go. Other then all of these tools there's nothing like having a torch around to burn the rusted pieces off the car.
To Help removing rusted bolts...
