427 heads question.
Old Sep 6, 2007 | 03:46 PM
sedowney's Avatar
sedowney
Default 427 heads question.
What application would the #396297 heads off of a 427 be? I am pretty sure the motor is out of an Impala (69, I think). So are the heads correct?
See below for the correct numbers.
Old Sep 6, 2007 | 05:03 PM
Durango_Boy's Avatar
Durango_Boy
Are you sure that's the correct casting number? I can't find that number anywhere.
Old Sep 6, 2007 | 08:50 PM
Roughrider's Avatar
Roughrider
I can't find that number either...from any source...books and manuals or on-line.
Make sure you copied the casting number down correctly and also make sure it isn't an aftermarket head.
Old Sep 6, 2007 | 08:55 PM
sedowney's Avatar
sedowney
No wonder I can't find anything, I may have copied the number down wrong. I will check again on Friday and post results.
Old Sep 7, 2007 | 07:36 PM
sedowney's Avatar
sedowney
Ok lets try again, my fault the first time.
Heads.
Driver side... F 8 8....GM4T....396428(maybe 9?)7
Passenger....I 10 9....GM4T....3964297
Block.........3963512....GM6
On the pad.....TO5I4LI....192091224
Thanks.
Old Sep 7, 2007 | 10:11 PM
Roughrider's Avatar
Roughrider
The block casting you give is for a 1969-1971 427-454 cubic inch Corvette, Chevelle, Impala, Monte Carlo.
For the cylinder heads, are you sure the numbers you're giving are correct? There is a casting number 3964290...it's for a 1970 454 cubic inch 390 hp Corvette, Impala, Chevelle and Monte Carlo (except LS6). They should be oval port.
That's the best information I can come up with for you.
Old Sep 8, 2007 | 09:09 AM
sedowney's Avatar
sedowney
Thanks for looking, I will get some good pics on sunday. Can I email them to you to see what you think? Thanks, have a good week end.
To 427 heads question.
