Fasteners upper windshield frame inner side
since I have no idea which fasteners, clips, nuts or whatever I will need for the inner side of the upper windshield frame I would like to ask you
I did not found anything in the well-known catalogues (only the molding reveal clips for the outer side). I put green circles around the holes in question: Picture
Thanks!
There should be 1 round holes with nuts welded to the frame, they take regular bolts.
There are 4 oval slots those take the spring steel U nuts.
There are 2 small round holes for sheet metal (pointed self tapping)screws.
Here is the page from Doc Rebuild and the part you are looking for is
M 68-82 Outer Molding 12 Piece Mounting Kit Does 1 car
with 6 mounting clips & 6 screws. 1009302 $11.75
Doc rebuild windshield PDF
Hope this helps.
Hope this helps.
I learned while restoring my 68 that the Doctor has all the nitty gritty stuff you need to restore your car that many of the guys who sell the fancy t-shirts and watches don't have. The best part is that his stuff is in stock, not just on a pretty page in a catalog. I never encountered a back order and I loved that since I have zero patience and want everything right now so I can keep working on my car.
Kurt
