Question on Voltage Regulators
Old Sep 9, 2007 | 08:09 AM
Jims79's Avatar
Jims79
Default Question on Voltage Regulators
I think I know how they work but do they stay 'on' all the time and draw amps from the battery? I was working on a 66 327 and noticed a draw on the battery when I was charging it. the regulator was making a low hum and when I unplugged it the hum stopped and so did the drain on the battery? could the regulator be bad or is the ign switch bad.
Old Sep 9, 2007 | 07:04 PM
SIXFOOTER's Avatar
SIXFOOTER
Something ain't right with that, maybe why you were charging the battery? Could be ign switch or regulator, but it should Not have a draw or make nay noise with the key off. period
Old Sep 9, 2007 | 08:42 PM
67-73-76's Avatar
67-73-76
Default Amp Draw
If the horn relay is hooked up wrong it will cause a draw on the battery with the switch in the off position.
Old Sep 10, 2007 | 10:23 AM
Jims79's Avatar
Jims79
W/the power off/key in off position I have power to the main/red line to the horn relay. no power to the green and full power to the black plug (not the ground black) is this normal??
To Question on Voltage Regulators
