I installed the Napa "Made in China" master cylinder last night. I had always thought that Corvette calipers all had two bleeders. One of my front calipers (I haven't gotten to the other side yet) only had one bleeder on the inside. There's not even a boss for the outside bleeder. The caliper does say "Delco" on the side. Has anyone else seen one of these? Are there any inherent problems with these (i.e. harder to bleed, etc.)?
Thanks!
Both my 69 and 72 have a single bleeder on the front, and 3 bleeders on the rear calipers.
Rd
There should only be 2 - at the top of each caliper half. The "bottom" hole should have a plug. Next time you are bleeding, put plugs in and save the bleeders for when you break one!
I wondered the same thing. But my rear Delco original's had 3 on my 69, I checked my 72 and found the same, and the replacement calipers from SSBC also had 3....
Maybe I got lucky, my two rear calipers have three bleeders each. Mutants of the braking world I suppose.
Generic remanufactured calipers frequently come with a bleeder screw where a screw in plug was installed orignaly by GM. They have a big box of replacement bleeder screws on hand and no new replacement plugs so they use what they have. No functional difference.
