more evaluation help
Old Sep 14, 2007 | 07:16 PM
gccch's Avatar
gccch
Default more evaluation help
Hi guys,
I'm becoming seriously interested in a car which I have still only seen pictures of. I have discussed with the owner, and if other things go well in my life in the coming weeks I will likely be taking a trip to see it, and maybe buy of course.
I'm looking for critical views. While it is nice to get "she's a beauty" type comments back, I really need the trained eyes to find faults. I also understand the pictures do not show the trouble spots, so I will be preparing myself to look at these areas on my excursion.
What I am told is this is the original paint, and is thought to be original in most every other way, but there is incomplete history on the car so I will need to check all the numbers to ensure this is the case. Otherwise I am not as interested.
http://picasaweb.google.com/cartlin/...98793894996306
Please comment.
Thanks,
Greg
Old Sep 14, 2007 | 07:45 PM
72LS1Vette's Avatar
72LS1Vette
The outside of the car looks pretty good. No bubbles in the fiberglass from the headlight support bar. Looks like some money has been spent on the interior. The engine bay looks a little uglier - not the engine itself but the surrounding area.
The big concern is that there are no pictures of the underside of the car. That's where all the expensive problems originate. Given the neglect in the engine bay I would insist on detailed pics of the frame, steering and suspension components.
Here is what mine looked like when I bought it:
And here is what was underneath. I knew there were rust issues but it was worse than I thought:
Rick B.
Old Sep 14, 2007 | 07:57 PM
Duke94's Avatar
Duke94
You need as many, or more, pictures of the frame and suspension as you have body pics. I think I noticed it had Michigan plates, if it spent it's whole life here, rust could be a major problem. Check out the bird cage close also. Looks like it needs a paint job, but if it's a real LT-1, it would be worth it. Is it a real LT-1?
Old Sep 14, 2007 | 08:01 PM
Durango_Boy's Avatar
Durango_Boy
I would be interested too, that's a beautiful car no doubt. Buuut, beauty is only skin deep, and there may be a whole mess of rust and rot waiting under that pretty body.
As said, get it checked out thoroughly before you put any money in the seller's hand.
Old Sep 14, 2007 | 08:03 PM
gccch's Avatar
gccch
The car has been garaged and driven very little since 1980, and is supposed to have about 40k miles. I am told it is a real LT-1, and has had very little work done to it since 1980 at least. I am researching prior to that, but it may not be available.
This is also the original interior but it has been worked on.... it's had the color changed (I've had other posts on this topic but would like to hear more comments with the pics).
Greg
Old Sep 14, 2007 | 08:04 PM
gccch's Avatar
gccch
Rick B.
Now those pictures are real eye openers! Thank you!!!
Do you have any other close ups of the problem areas?
Old Sep 14, 2007 | 08:16 PM
VetteThunder1's Avatar
VetteThunder1
I grew up in the north east (Canada actually). I can tell you what driving a car only 5 winters can do to the suspension and other parts underneath. I would check carefully the frame and birdcage. Especially the #4 body mounts, they will tell you a great deal. Mine had rust worse then 72LS1Vette's Vette and it was a California/Arizona car all its life. So even if it was garaged since 1980, that might not mean too much.
It is a very nice looking car indeed from the pics.
Andrew
Old Sep 14, 2007 | 09:50 PM
72LS1Vette's Avatar
72LS1Vette
Sure. Here are a couple more of the trans crossmember area. My frame had all kinds of scale falling out of the lower holes every time I hit it. If you examine the car, reach into any holes you can see in the frame and feel for rust. If you get thick chunks of scale you can be sure that the frame is much thinner than it was originally. If the seller will let you, hammer on the areas around the trailing arm pocket and trans crossmember.
Rick B.
Old Sep 16, 2007 | 09:02 AM
gccch's Avatar
gccch
Thanks for the added pics. I'll let you know how I Make out but it may be several weeks before I make the next move to look at the car.
Old Sep 16, 2007 | 09:39 AM
schmegeggie's Avatar
schmegeggie
The lines look really good in the pictures. Is it a real LT1? Documented? Why no underside pictures? That in itself points to something the seller may be hiding, because a Vette buyer usually looks underneath first(well not always).
As stated above, you've got to see the car and find out. If it's been sitting that long you're looking at some issues like brakes, etc.
Lot's of experience in here to fall back on.
Old Sep 16, 2007 | 12:35 PM
gccch's Avatar
gccch
Schmeggie,
Thanks for the input. It is supposed to be a real LT-1, which is the first thing I will confirm. The brakes were redone last spring, so it has had some maintenance during its long history with the current owner (since 1980). The underside pics were not provided to me initially but the guy does not have a lift and the pics were simply done in his driveway.
BTW, how would the LT-1 be documented? I don't think the PoP is available, and I am guessing the tank sticker is still on the tank. Is there something besides the engine stamp?
Greg
Old Sep 20, 2007 | 11:08 PM
wjsullivan's Avatar
wjsullivan
A couple of things to look at for sure:
- Winshield posts from the top corner to as far down as you can see. Take a look at the metal and look for rust, pitting, holes, etc. Look down at where the post meets the body and check it carefully. Rust there is a bad thing and hard to deal with.
- Take a look under the rear end. Lay under the car behind the seat infront of the rear tire. Take a look at how rusty the trailing arm that the tire mounts to is. Look at the frame crossmember there. Look forward to the trans crossmember for rust. Take a look at the exhaust. Check out the drive shaft and half shafts. Move behind the tire and take a look at the spring where it mounts. In my case the spring bolts had torn away from the differential cover.
- Above the tire take a look at the #4 body mount reinforcement and bushing. Also check out the mount. See if it looks like it is solid or not.
- If you can, take off the covers on the #3 body mount, on the just behind the door, accessable just in front of the tire, and take a look in for rust or damage.
Just my 2 cents.
Old Oct 27, 2007 | 02:10 PM
gccch's Avatar
gccch
Guys,
I have added some more pictures of this car including some of the undercarriage, carburetor, engine pad....
Now I know it is NOM, but am I still interested? I think so. It's a 71 engine from an LT1 Z28, so it is pretty close match. The car is still an LT1 in original paint (still with limited docs).
What do you all think with the updated information?
http://picasaweb.google.com/cartlin/Corvette
Old Oct 27, 2007 | 04:47 PM
pbcanney's Avatar
pbcanney
awfully dark in the carb
http://picasaweb.google.com/cartlin/...78987264129266
Old Oct 27, 2007 | 05:34 PM
vettehed's Avatar
vettehed
A 71 LT1 is pretty easy to distinguish from non-LT1's:
1) LT1's have only one fuel line and all other 70-72 Corvettes have a fuel return line running parallel to the fuel supply line. This should be a dead giveaway as a fuel line cannot be replaced (intact) with the body on.
2) LT1's utilized a TI distributor. If no TI amp, distributor, or harness if there, then something is amiss.
2) LT1's had a 6500 tachometer. The LS6 did too, but not the others.
3) Should have caps instead of u-bolts on the stub axles.
If it passes this test, especially item #1, then its likely an LT1
Old Oct 27, 2007 | 06:58 PM
early shark's Avatar
early shark
It appears to still has the original carbon steel double wall GM exhaust piping. Very difficult to find. Especially the original mufflers.
Old Oct 27, 2007 | 07:56 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Looks like it probably has an LT-1 Tach, but it is most likely broken since there is an aftermarket tach on the column. I could only see up to 6k with no redline visible.
Bullshark
To more evaluation help
Old Oct 27, 2007 | 08:09 PM
gccch's Avatar
gccch
I'm pretty confident it is the LT1 as it is in original paint and with this owner since 1980. Minimal to no work has been done to it in that time. It's been driven very little.
Old Oct 27, 2007 | 08:10 PM
gccch's Avatar
gccch
How about the undercarriage and frame?
Old Oct 27, 2007 | 08:15 PM
pbcanney's Avatar
pbcanney
maybe its just the lighting, but the paint appears to be a different shade from the doors forward (picture number 1)
