engine numbers...
Old Sep 16, 2007 | 09:42 PM
gccch's Avatar
gccch
Default engine numbers...
Guys,
I was getting serious about a car a long distance away, and not sure I want to go see it anymore. It all sounded very good until I found out the engine numbers either do not match or were scratched off. I'm looking for an investment quality car, so I'm pretty put off by this.
Is there another place on the block to check numbers? Or is this just casting date codes? I've got to re-evaluate whether or not to spend more time on this one.
Greg
Old Sep 16, 2007 | 09:55 PM
Durango_Boy's Avatar
Durango_Boy
Where on the block did the guy get the numbers or the report that it had been scratched off?
The best place is that pad right in front of the passenger head. What he may have meant by scratched off is that if the motor was rebuilt and the block was decked those numbers might have been ground off in the milling process.
Is the engine the only part with a no number situation?
Old Sep 16, 2007 | 10:13 PM
gccch's Avatar
gccch
I don't have a clear picture, so bear with me, but the numbers on the number pad are not legible. The engine has been in the car for at least 27 years, but the car is 36 years old. The seller does not have prior history.
So, he acknowledges the engine numbers are "illegible". Is there any way to identify the type of block and date of manufacture?
How were replacement engines handled by GM (not that this is the case necessarily).
Old Sep 17, 2007 | 01:09 AM
vettebuyer6369's Avatar
vettebuyer6369
If we knew what year the car was, it would be interesting.
What is the part number of the block, and what is the casting date? And, in what format is the casting date (Y? YY?)
Issues like price, car, what you mean by "investment quality", how far you are travelling and more all affect the decision to get on the plane.
Old Sep 17, 2007 | 06:47 AM
gccch's Avatar
gccch
The car is described as much as I know in this post:
http://forums.corvetteforum.com/show....php?t=1813145
It's a '71. I don't know what if anything is showing on the stamp pad. I need to travel 750 miles to look for myself. It's in southern Michigan. The mystery seems to be in the years between '71 -'80... Otherwise the car is very clean and appears representative of a low mileage LT-1.
Old Sep 17, 2007 | 08:04 AM
tlynam's Avatar
tlynam
The engine casting number and casting date are facing upward on the back of the block on the flange that bolts to the bell housing. The casting number is on one side, the casting date is on the other. The seller should be able to photograph them from under the hood. The numbers will tell you if it is the correct type of block for an LT-1. The casting date is a clue as to whether it's the block that came with the car. Typically, the engine cast date should be within 8-10 weeks prior to the body build date on the trim tag, although, smaller and larger gaps have been documented.
Old Sep 17, 2007 | 12:20 PM
Mike Ward's Avatar
Mike Ward
If the pad is blank, it doesn't matter a whole lot in terms of value what the history of the engine is.
Price this as a non-original engine car.
Old Sep 17, 2007 | 12:26 PM
gccch's Avatar
gccch
Yeah, that is probably the wise thing to do. It would be good to understand what type of engine is in the car, though. By all other accounts this appears to be a legit low mileage LT-1 car, but is now NOM.
Old Sep 17, 2007 | 01:32 PM
GD70's Avatar
GD70
I've been told you can put mecuric acid on the pad and it can sometimes reveal the numbers on the pad even if the heads were decked for a rebuild and you can't see them. I agree with the other commentes re; the casting info on the rear of the block. Have pics sent of the entire car as well in more detail then in those pics on your earlire post.
Old Sep 17, 2007 | 08:22 PM
Mike Ward's Avatar
Mike Ward
The casting number for an LT-1 is 3970010 - but that's the same casting number for every other small block built by GM. All cars lines not just Corvette.
There's probably thousands of blocks around that would show the same casting number and reasonable date code range.
Old Sep 17, 2007 | 08:28 PM
gccch's Avatar
gccch
So the casting for a LT-1 block is the same as a base model 350? The engine block is the same?
Old Sep 17, 2007 | 09:07 PM
Mike Ward's Avatar
Mike Ward
Yup, no difference. Same block was also used in Dad's Impala, Grandma's Biscayne and Uncle Ed's milk delivery trucks and school buses.
Old Sep 17, 2007 | 09:31 PM
gccch's Avatar
gccch
OK, learned something new... did the other applications also get coded with VIN numbers? That would be a difficult thing to manage for GM even with todays controls!
Old Sep 17, 2007 | 09:50 PM
Mike Ward's Avatar
Mike Ward
I believe all car lines had a VIN stamp on the block as well as frame and transmissions. They were stamped with the partial VIN code while on the main assembly line. No big deal to manage.
Old Sep 17, 2007 | 10:26 PM
jjarrett's Avatar
jjarrett
hi! i have a 76 project car that i think the motor and trans. have been replaced. here are the #'s i found on the block. VO9IZCLS. can anyone identify this engine?--many thanks!!---john
Old Sep 17, 2007 | 10:34 PM
vettebuyer6369
Whooooa, slow down here. While the 010 block was used on all types of Chevy vehicles, did the casting date format not separate the Corvettes from the rest of the crowd?
In specific, I believe the Flint blocks, used in the Corvettes, used a single-digit casting date year ("9") as opposed to the Tonawanda casts (non-Corvette) which used 2 digit formats ("69"). This is helpful indetermining a Corvette block as well as pad numbers and codes.
Old Sep 18, 2007 | 07:22 AM
Mike Ward's Avatar
Mike Ward
Possibly true, but Flint made the majority of 0010 blocks for all car lines not just Corvettes.
To engine numbers...
Old Sep 18, 2007 | 10:28 AM
Richard454's Avatar
Richard454
Guys,
Greg-
If your looking for an Investment-then do what I do when considering an investment- Pay someone more knowledgeable to check it out.
I'm sure there are many forum member that would be glad to help you out, look over the car, etc.
I don't consider my cars as an investment-they are a hobby and I'm happy to break even.
Richard
Old Sep 18, 2007 | 10:49 AM
vettebuyer6369
Right, I don't believe you can definitively prove the engine is right, but you can avoid ruling the motor out as wrong by verifying the casting format. And, if the format as well as the comparative dates line up, the car will judge well at NCRS which does affect the overall value, which is what he's concerned about.
Old Sep 18, 2007 | 12:19 PM
Mike Ward's Avatar
Mike Ward
Didn't see NCRS mentioned anywhere in this thread???
I'm not sure a car that gets judged with a big deduct for a poor pad will do much for value- in a positive sense.
Shame on people who get their cars judged just to boost the value anyway.
