Radio Install troubles - help!
Old Sep 18, 2007 | 03:47 PM
Caughtaflyer's Avatar
Caughtaflyer
Cruising
Default Radio Install troubles - help!
I am installing a new radio. When I removed the old one it had power. Now when trying to install the new one the yellow wire has no power. I am thinking I blew a fuse, but cannot find one. Any thoughts?
Old Sep 18, 2007 | 03:50 PM
Durango_Boy's Avatar
Durango_Boy
The yellow wire from the dash is an IGN source, meaning the key must be turned to the ignition position.
Did you remove an after market head unit or the stock radio? Most after market head units use yellow as the constant 12V and red as the IGN, where in a C3 the yellow is IGN.
If your yellow doesn't have power then you may have a blown IGN fuse and you need to check that out.
Old Sep 18, 2007 | 03:52 PM
Caughtaflyer
Cruising
it was an after market head unit, but it used the original black, yellow, and gray (not in use) wires. I had the ignition on when testing, still no power. Where is the IGN fuse located?
Old Sep 18, 2007 | 03:56 PM
Durango_Boy
If the car runs it may not be the IGN fuse now after I think about it.
I would however, trace that wire back a bit and test it closer to the fuse panel.
Also, there is an accessory location, ACC, in that fuse panel that you can run a wire for the same functions as an IGN lead would do.
Old Sep 18, 2007 | 03:59 PM
Caughtaflyer
Cruising
alright, last stupid question...where is that fuse panel? I have looked everywhere!! We not everywhere I guess since I cannot find it. It is a 76 by the way.
Old Sep 18, 2007 | 04:15 PM
Caughtaflyer
Cruising
Thanks Durango! Anyone else have anythoughts? Or can someone tell me were the damn fuses are (this is getting frustrating!)!
Old Sep 18, 2007 | 04:47 PM
RunningMan373's Avatar
RunningMan373
Under the dash, on the drivers side fire wall, near the door. the fuse is called TCS SOL RDO, a 10A fuse. You will need to run a jumper from the BATT terminal in your fuse box, there is a male spade lug in a small box with "BATT" printed under it in the fuse panel,, crimp a female lug to a 14 OR BETTER gauge wire and plug it in and run it to the stereo to the constant power in. The yellow wire should be used for the ACC input to the radio, the black wire is used for ground. The grey is for lights if your stereo requires it, if not, tape it up and leave it off.
Old Sep 18, 2007 | 07:41 PM
Caughtaflyer
Cruising
Surprise surprise! The TCS SOL RDO is worn off of the box. Do you know which spot it is located in?
P.S. Excellent Info everyone! Thanks for your help
Old Sep 18, 2007 | 08:23 PM
RunningMan373
should be upper center, long fuse,, take a flash light and look for a fuse burned in half in the glass. if it's burned you will be able to see it.
To Radio Install troubles - help!
