fixed rear window to removable window ?
Old Sep 20, 2007 | 10:05 AM
phil w's Avatar
phil w
Default fixed rear window to removable window ?
Hi Any one know if this can be done? Replace a 77 rear window with a removable one Thanks Phil W
Old Sep 20, 2007 | 10:52 AM
Durango_Boy's Avatar
Durango_Boy
Yep. I have a '77 and I put in a removable rear window. IMBatman has a '77 and he did it. Curtis74 did it to his '74.
All you need is the window w/ frame, latches, pin guides, window frame weather strip seal, 3M gasket adhesive, J-clips and screws, a drill, a file, halo panels with the cutouts, and a few friends with some extra time and spare hands to hold the seal in place while it's being glued.
Old Sep 20, 2007 | 12:09 PM
Erics Quick71's Avatar
Erics Quick71
Sounds simple
I have a 72 with the removable window.
What is the real benefit of having it out?
I have but seems like a pain for a little benfit.- Anyone?
Old Sep 20, 2007 | 12:14 PM
Durango_Boy
Originally Posted by Erics Quick71
Sounds simple
It moves the air out of the cabin with a lot less turbulence than the fixed window cars. I took my rear window out years ago before I even knew a removable one would fit and the difference was fantastic. The better cabin flow whipped the hot air that usually lingers in the floor boards right out of the car.
It's a fantastic change and I wish they never would have dropped that option for the pre-bubble C3s.
Old Sep 20, 2007 | 01:09 PM
GD70's Avatar
GD70
Makes it feel more like a full roadster.
Old Sep 20, 2007 | 01:43 PM
Erics Quick71
Think I will need to give it another shot. Last time was Carlisle Saturday and when the storm hit was just another thing I needed to put in place to keep out the rain.(attempt to keep out the rain I should say).
I will try again tomorrow should be 80 and sunny here in the NorthEast!
Old Sep 20, 2007 | 03:38 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Hi Phil W,
I am doing this mod on my 75.
There is a lot of info on this subject in the archives. If you go to the Search menu in red toolbar, click on to drop down menu, click on advanced, type in "removable rear window", click on archives and scroll thru forums to either C3 General or C3 Tech, you will find almost 20 pages of actual info.
I use this search a lot. Only problem is pics are not saved very long in archives (space issue).
Also blow-ups in catalogs like Ecklers and Riks will give you details.
Good luck!
Peace
Bman
Old Sep 20, 2007 | 05:23 PM
harrin's Avatar
harrin
Sounds simple
mine is out all the time, gives much better air flow, IMHO
Old Sep 20, 2007 | 08:10 PM
cosmicvette's Avatar
cosmicvette
The removable rear window makes the biggest difference, as has already been said it makes the air flow feel much more like a vert, I don't know why they would ever have stopped installing it.
In the three years I have had my '70 the rear window has been in maybe once or twice.
Go for it.
Old Sep 20, 2007 | 10:21 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Go for it.
The bean counters got hold of it.
68-72:
latches
window, aluminum frame, guide pins
weatherstrip and glue
halo panels with a complex notch
guide plates
73-77:
window
glue
straight halo panels
plastic window trim
Old Sep 20, 2007 | 11:15 PM
Busrydr's Avatar
Busrydr
From experience, before you go buying each item piece by piece, look hard and long for someone that has a complete kit or a kit with most of what you need.
The other route is to hold out on a piece by piece purchase until you know the part you're getting is rock bottom pricing.
I guess this was a fairly priced upgrade in the not so distance past. But now if you find these items in great shape on e-bay or a forum they are not alway cheap. I found a great deal on an original window and frame with pins, latches and even the original latch bezels that most don't bother with. I picked up the guides, guide plates and rear seal new from a vendor. With the latch bezel I can cut my original roof panels but I'm still looking for a 70 -72 set with the latch cut outs molded in.
After I started buying parts I ran across a complete set up with all parts needed including the storage tray. Had to pass because I already had most of what I needed and the seller would not break up the package.
Be patient. These parts have a wide range of pricing. You could spend $75 or $275 for the exact same window and frame.
Old Sep 21, 2007 | 02:20 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Keep an eye on eBay for the 69L-72 halo panels with the molded latch recesses. Durango and I have each found an original set in good shape there for very reasonable prices.
Old Sep 21, 2007 | 07:21 AM
mdbelanger's Avatar
mdbelanger
got some pics of this please I like this idear.
Thanks.
Old Sep 21, 2007 | 11:35 AM
Busrydr's Avatar
Busrydr
I did see 1 good panel but no match. I'll keep looking and if you run across a pair, let me know. I see the term "halo" is often used to describe the panel. I'll change my search to include that word as well.
Thanks,
Steve
Old Sep 21, 2007 | 07:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Thanks,
Steve
Friendly eBay tip - if you put words (or numbers) in parentheses, separated by commas, the search feature will read that as an "or". For example, "1968 (Ford, Mercury) engine" will search for "1968 Ford engine" AND "1968 Mercury engine". I have tons of search strings set up that way - it's a great way to deal with common misspellings.
The panels don't show up all the time, but they are available on a fairly regular basis. Mine came with an original kick panel, too. Look once a week or so, and you should find some before too long.
Old Sep 29, 2007 | 01:05 AM
Busrydr's Avatar
Busrydr
Got em. Thanks
Now I just need to determine how to make the striker for the tray push button latch. I have a 72 tray that used the push button style latch.
I believe someone stated this is teh same striker used on the storage doors. Can anyone confirm?
Old Feb 26, 2008 | 11:49 AM
halfmoontrail's Avatar
halfmoontrail
Thanks to everyone for the detailed responses, I'm looking forward to doing this to my '74.
Steve
Old Feb 26, 2008 | 06:40 PM
RunningMan373's Avatar
RunningMan373
you know what would be cool, if someone made a sliding rear window for '73s to 77's. like a truck slider.
Old Feb 26, 2008 | 07:22 PM
Vet76te's Avatar
Vet76te
Thanks,
Steve
These panels are available NEW in your color choce for $89.00 a pair from all the major parts suppliers. I got my set from Corvette America.
To fixed rear window to removable window ?
