I'm not quite sure what your question is. Is it possible to bolt an 82 crossmember into your 76? Sure if you are trying to bolt in a 700R4, but just remember, your crossmember has holes for a dual exhaust system, even if it doesn't have a dual exhaust. The 82 crossmember is designed for a 2-1-2 exhaust system. I just recently installed an aftermarket crossmember from Bowtie that holds my 700r4 and allows for a true dual exhaust underneath. So now I can drop the exhaust without dropping the crossmember.
Bee Jay
i want to install a 700r-4 in my 1977 vette to replace my th350. rather than modifying my crossmember, will a crossmember from a 1982 vette bolt right on to mine?
No, it only works in a 79-82 and even then you are limited to single exhaust.
Bowtie must be busy because i cannot get them to reply. But does anyone know if this unit will work with a 4L60E? This is a hangup in my LT1 swap into my 81. thanks
You do not need a new crossmember, only this new trans. support bracket.
