Duel Exhaust......Help
Old Sep 24, 2007 | 03:20 PM
Burnt71's Avatar
Burnt71
Default Duel Exhaust......Help
I'm putting duel exaust on my 1980. Where can I find a bolt on crossmember with two cutouts ?
Old Sep 26, 2007 | 04:02 PM
vetteonr's Avatar
vetteonr
No need to. I put a true dual system on my '80 from Mid America, and regardless of what some people say, mine went on pretty easy, and I have headers.
Old Sep 26, 2007 | 04:10 PM
BoundandBlocked's Avatar
BoundandBlocked
Sir, I demand satisfaction.
Old Sep 26, 2007 | 04:31 PM
markdtn's Avatar
markdtn
You could use a BowTie overdrives tubular crossmember and adapt it some. I'm sure you are retaining the cats........
Old Sep 26, 2007 | 06:14 PM
RagTop69's Avatar
RagTop69
What? It sounds as though you are inviting a dual, sir! (or is that a duel?......oh well).
I believe duel exhausts are illegal everywhere but Heidelburg, Germany.
Old Sep 26, 2007 | 07:36 PM
MN80Vette's Avatar
MN80Vette
You don't need a new cross member to put dual exhaust on your '80. I made a very simple modification to the cross member on my '80 and ended up with an EXCELLENT true dual exhaust system that improved performance noticeably on my butt-o-meter.
Old Sep 26, 2007 | 07:54 PM
willem wallace's Avatar
willem wallace
Default crossmember
Hi Burnt,
I just started modifying my crossmember this week. Have it disected and welded back together. All that is left is to make up the bottom brackets. Work is interfereing with my freetime, damnit! I am running 2.50" pipe with a crossover, and will be able to unbolt the entire system from headers back, in one peice. It seems like a worthwhile modification, and if you have basic wrench skills, is a pretty simple modification. I have documented the procedure with photos, but don't have ability to put them on forum. If you e-mail me, I can send some to you, as an attachment.
Willem
Old Sep 26, 2007 | 08:58 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by willem wallace
Hi Burnt,
Willem
Get a Photobucket account. You can upload your pics and post links here or use the [IMG] link and post the pics.
Rick B.
Old Sep 26, 2007 | 11:56 PM
Burnt71's Avatar
Burnt71
I spelled dual wrong no wonder I couldnt find anything when I searched
Old Sep 27, 2007 | 06:26 AM
stingr69's Avatar
stingr69
I have the original manifiolds. It went on fairly easy. Not perfect but I can live with it. I added a crossover where the pipes come close together.
-Mark.
Old Sep 28, 2007 | 09:27 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
-Mark.
I've got duals with no crossover. A set of cats (whose days are very numbered) and monza tips. What are the advantages of a crossover and are there any real advantages with x-pipe etc. crossovers?
Old Sep 29, 2007 | 05:58 AM
stingr69's Avatar
stingr69
My opinion is there are advantages that make it worth adding. The sound is somewhat more mellow with adding a crossover. You may experience an increase in torque below the torque peak with a crossover. I think the effects may be more pronounced on a car that has already maxed out the exhaust system and then have a crossover added - but that is not something I can back up with a dyno. If you had more than enough exhaust system in the first place the added torque will be less IMHO. Part of the reason the crossover works is because the engine now has 2 pipes to exhale out of rather than just one for every exhaust pulse but again, my opinion. They do work.
The X-pipe probably works the best but I have not tried one. I do know that some professionals use them so they do work better.
-Mark.
Old Sep 29, 2007 | 09:14 AM
guitarcrazy02's Avatar
guitarcrazy02
I put duals on my 81 and I didn't have to change the crossmember. I got MidAmerica's system. It took a while to get it fitted up right and get it all aligned, but it's tucked right up against the crossmember and no problems there. It's 2 1/2", and I've compared the ground clearance to my dad's 69 with factory exhaust, and the difference is negligible. I've only scraped it on the ground once, but that was my fault. You'll hit the spoiler up front before the exhaust.
Old Sep 29, 2007 | 09:39 AM
MN80Vette's Avatar
MN80Vette
Whether you use OTS like the ones from Mid America or modify the cross member and go near-straight back on the left depends on the headers. If you keep the original ram horn exhaust manifolds, then the OTS pipes are the easiest to put on.
I have full-length headers on my '80. In order to get the left pipe to the right side of the car like original, the left pipe would have needed a 90 deg. bend just behind the collector. Sharp bends are bad for flow.
IMO, if you're converting to true dual exhaust, you should go all the way and put full length ceramic headers on also to get the most flow improvement.
To Duel Exhaust......Help
