steering wheel swap
Old Sep 25, 2007 | 10:34 PM
Davew/75's Avatar
Davew/75
Default steering wheel swap
What is involved in putting a new steering wheel in?
i have a 75 and well, it just seems too big! when i get in, its just a pain in the butt...
is it a "plug n play" kind of thing? does any steering wheel work?
what should one cost me?
Old Sep 26, 2007 | 07:16 AM
Durango_Boy's Avatar
Durango_Boy
You will want a Corvette specific after market wheel for ease of install. If it's a universal you need an adapter kit and that usually looks trashy.
Many of the main vendors carry Corvette specific wheels but they do not come cheap. I paid a lot of money for my simple four spoke.
Old Sep 26, 2007 | 07:21 AM
markdtn's Avatar
markdtn
A Corvette specific wheel will be remove screws, install new on existing hub. It would also work with your telescoping function if you have it. Universal wheels replace the hub and you lose tele.
Old Sep 26, 2007 | 08:16 AM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
I installed a Grant 791 which is a direct bolt on for the corvette, its has a diameter of 14 inches and is flatter than the stock wheel. I purchased it from Jegs.
Old Sep 26, 2007 | 11:06 AM
kayosnes's Avatar
kayosnes
Changed to th 14" from ecklers. easy to change. 10min.
http://www.ecklers.com/product.asp?p...9&dept_id=1719
Old Sep 26, 2007 | 11:19 AM
SuprJames's Avatar
SuprJames
I can't believe it.....$116 from Jegs, $120 from Summit, and $99 from Ecklers!!
Old Sep 27, 2007 | 02:39 AM
GroundPounder's Avatar
GroundPounder
I installed mahogany(look alike) steering wheel.
You just need to be careful not to break the horn cap when you take it off.
Old Sep 27, 2007 | 07:59 PM
Davew/75's Avatar
Davew/75
that was my concern...i dont want to break it. How does it come off?
Old Sep 27, 2007 | 08:00 PM
Davew/75's Avatar
Davew/75
i like that wheel alot. i need to measure my wheel now. i dont know how big it it. Anyone know what the stock wheel measured?
btw, i dont have tilt/tele
Old Sep 28, 2007 | 03:00 AM
GroundPounder
You need to pry it off. I inserted screw driver into between horn button and retainer, and pried off the button. If you do it carefully, you won't break it.
Oh, you had better disconneted the battery so that you won't let it horn when working on it.
Old Sep 28, 2007 | 05:44 AM
RunningMan373's Avatar
RunningMan373
Stock is 15"
you could also go with a Grant Signiture wheel kit, and have a differnt choice of wheels. Install kit grant #4193 and shortening adapter hub grant #4001, and you can use any grant signiture wheel you want.
Looks like this, with the wheel I chose,, a 15" wheel, that I went with. Sizes down to 12" if you want.
But to remove your existing hub and wheel, you will need to get or borrow a steering wheel puller,, about 9 bucks. tha's all the tools you need, it's fun, really
I have to say though, that if I had known that that wheel existed, at the time I was doing the swap, I would have gone with the direct fit wheel. looks great and is the righth size too. i would go withthe ecklers wheel,, it's a grant anyway, but, if you need an even smaller wheel, the signiture adapter is the way to go. C.
(All personal experience; no warranty expressed or implied, your milage may vary, some settling may occur during shipping and it's all fun until somebody loses an eye.)
Old Sep 28, 2007 | 06:38 AM
Ganey's Avatar
Ganey
I changed to the Grant st. wh. polished slotted spokes w/ black leather a long time ago. Shallow dish moves closer to dash (great if tall). Less than 14" & direct bolt on. Ideal !
http://ganeys.home.sprynet.com/CorStIntWh.JPG
Fits 63-75 &
77-82 w/ tilt/tele.
Old Sep 28, 2007 | 08:26 AM
RunningMan373
Fits 63-75 &
77-82 w/ tilt/tele.
Old Sep 28, 2007 | 10:09 AM
Trae1976's Avatar
Trae1976
That is the wheel I used, and I'm really happy with it. Since mine is a '76, I had to use an adaptor, but it looks fine to me.
Old Sep 28, 2007 | 01:41 PM
manhatten's Avatar
manhatten
Default Steering Wheel
Beautiful installation
Old Sep 28, 2007 | 04:01 PM
GroundPounder
here is mine.
I like wood like steering wheel for classic look. Downside is it becomes slippery when my hand get sweaty in hot day.
To steering wheel swap
