engine #s
Old Oct 4, 2007 | 04:57 PM
tbschilz's Avatar
tbschilz
Default engine #s
can anyone tell me if these # make sense on a 1976 vette l-82
vo3or817tyc c8u105715 on the engine,I put a crate motor in put saved motor that was in to rebuild if it match's
Old Oct 4, 2007 | 06:56 PM
427basketcase's Avatar
427basketcase
Try this site http://mortec.com
Old Oct 5, 2007 | 12:09 AM
Tom73's Avatar
Tom73
vo3or817tyc c8u105715 on the engine...
Not really. The TYC is the engine usage code, but the codes that start with a "T" are usually a truck engine. As for the other, are the last six of you VIN 105715? I would have to bet not.
tom...
Old Oct 5, 2007 | 10:44 AM
ROBMERRILL's Avatar
ROBMERRILL
1975-1977 Engine Block Casting Numbers:
Casting # Cubic Inches Description/Application
3970010 350 165 & 205 Horsepower (1975)
350 180 & 210 Horsepower (1976-77)
1976 Engine Identification Codes:
Engine Code Cubic Inches Order Code H.P. Applicable Equipment
CHC 350 L82 210 4-Speed (Federal)
CKC 350 L82 210 Turbo Hydra-Matic 400 (Federal)
CKW 350 L48 180 4-Speed (Federal)
CKX 350 L48 180 Turbo Hydra-Matic 350 (Federal)
CLM 350 - - Unverified
CLR 350 - - Unverified
CLS 350 L48 180 Turbo Hydra-Matic 350 (California
Old Oct 5, 2007 | 10:55 AM
Tom73's Avatar
Tom73
Just looked up the TYC code. It was used twice, once in '75 and again in '78.
In '75 it was for a 350ci/145hp 2-v carb in a C-10 and 1500 truck.
In '78 it was for a 350ci/165hp 4-v carb in a C-20 to 3500 truck.
Old Oct 7, 2007 | 11:30 PM
tbschilz's Avatar
tbschilz
thank you very much #s don't match, got high performance crate engine allready in hopefully hp! got from checkers when I get back home I'll check those #s somehow
To engine #s
