Chevy Orange paint
Old Oct 6, 2007 | 09:00 PM
AWilson's Avatar
AWilson
Default Chevy Orange paint
When it comes time to painting my engine, what brand name of Chevy Orange color has provided the best results?
Sprayed or brushed?
Primer or direct to the metal?
Anyone try the POR engine enamel?
Old Oct 6, 2007 | 09:51 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
VHT Engine Enamel SP-123 Chevy Orange...sprayed.
Old Oct 7, 2007 | 09:46 AM
eastltd's Avatar
eastltd
Go for the POR-15. It can be brushed or sprayed.
I brushed my block and sprayed the bolt on parts.
Old Oct 7, 2007 | 10:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: original engines were always sprayed at Flint, no primer.
Old Oct 7, 2007 | 10:19 AM
schmegeggie's Avatar
schmegeggie
MMMMM...Pretty!
Old Oct 7, 2007 | 02:13 PM
AWilson's Avatar
AWilson
Default eastltd question
WOW that looks nice. How many coats on the block?
Old Oct 7, 2007 | 07:48 PM
eastltd's Avatar
eastltd
The block took about four good coats and then a little touch up here and there.
Old Oct 7, 2007 | 08:21 PM
Cosmo Kramer's Avatar
Cosmo Kramer
AWilson..........Try this link:
http://www.hirschauto.com/newpages/paint.htm
I'm rebuilding my '70 L46 and am using Hirsch Auto's "Chevy Orange." According to their web site, it isn't necessary to primer the cast iron parts. Also, check out their exhaust manifold paint. From what I've researched, their engine paint looks to be the best.
eastltd..........Cool headers. Are they Hooker ceramic?
Old Oct 7, 2007 | 08:26 PM
eastltd's Avatar
eastltd
Sure are! They sound as good as they look!
Old Oct 7, 2007 | 09:00 PM
BarryK's Avatar
BarryK
I used the Hirsch Auto engine paints on both my '65 for the Chevy Orange and on my '78 with the Chevy Blue paint.
I was VERY happy with the paint and results on both.
As mentioned, Hirsch recommends NOT priming the iron block before using their paints although you do need to first prime the steel oil pan
this is the Hirsch Auto Chevy Orange on the '65
Here is the Hirsch Auto Chevy Blue on the '78 during motor reassembly
Old Oct 8, 2007 | 10:20 AM
eastltd's Avatar
eastltd
Nice work
If the 78 turns out as good as your 65 you'll have two show winners!
Old Oct 8, 2007 | 12:01 PM
rosslato's Avatar
rosslato
not only did i use the pro-15 ceramic eng paint on my eng but also did my frt end suspension w/it, brushed it on all parts n no brush marks. it looks like it's been powdercoated
To Chevy Orange paint
