Early or late 69?
Old Oct 9, 2007 | 08:43 PM
pbean's Avatar
pbean
7th Gear
Default Early or late 69?
Got a 69 coupe that i'm workin on. How do I tell if it's a early or late 69 car? Seems like some parts I have looked at buying has wanted to know this info. Thanks.
Old Oct 9, 2007 | 10:01 PM
19LEW71's Avatar
19LEW71
vin from 194379s700001 to 194379s738762
38762 total cars
22129 are coupes and 16633 convertibles
Old Oct 10, 2007 | 08:41 PM
C3 Stroker's Avatar
C3 Stroker
Build dates after June 1969 are generally considered "late".....parts may vary, though.
Old Oct 10, 2007 | 08:51 PM
nihil's Avatar
nihil
As FrankVincent said, it depends on the part. I've found both on mine.
Old Oct 10, 2007 | 10:03 PM
mstanton's Avatar
mstanton
Early or late car is easy, look at VIN, body build date. What you are really asking is for a given part do you need the early or late variation. That depends on what part you are talking about. Most cars will have a mix of early and late parts. Changes to parts happen throughout the production run. Some happen very early and some happen very late. The most accurate way to know what you need is to research the difference between the parts, see what is on your car, and order the correct replacement, assuming you are replacing the original part. The next best thing is to buy an NCRS technical information manual. It will give in detail how parts changed and give a vin range in which the changes occured.
Old Oct 10, 2007 | 10:37 PM
elevatordude's Avatar
elevatordude
Default check it out
check this site out it will tell you your cars aprox b day
http://www.c3registry.org/index.php
Mine was Aug 12 , 1969
To Early or late 69?
