Trailing Arm Spring Cushion Cups
Old Oct 10, 2007 | 04:31 PM
stinger12's Avatar
stinger12
Default Trailing Arm Spring Cushion Cups
I just received a new pair of these in the mail the other day. How do I flare them onto the trailing arm? Note: The picture I am posting is before I removed the old cups from my trailing arm
Old Oct 10, 2007 | 04:44 PM
78Vette-SA's Avatar
78Vette-SA
I use a ballpeen hammer and a press. Use the ball end to swage the cup into position and then flip the hammer over and use the flat end to flatten down the swaged ends. Looks like factory when done.
I put a in the cup to hold it in position and to provide a surface to press against.
Old Oct 10, 2007 | 05:17 PM
stinger12's Avatar
stinger12
What did you put in the trailing arm to prevent it from getting crushed while in the press? what size of ball peen hammer did you use?
Old Oct 10, 2007 | 08:33 PM
78Vette-SA's Avatar
78Vette-SA
My bad writing, sorry. I used a deep socket through the hole and placed the cup on it.
Don't know what size hammer it was. I would say something with about a 3/4" - 1" ball on the peen size would do. The flat end has to be enough to cover the crushed sleeve to flatten it in one pressing.
Old Oct 11, 2007 | 01:06 AM
stinger12's Avatar
stinger12
It worked like a charm! the only thing i did different was I cut some iron pipe and plumbed together some pieces which could be placed in the arm and then ezpanded so it preesed the bottom of the cup tight against the trailing arm when it was in the press...results couldn't have been better!
Old Oct 11, 2007 | 08:15 AM
78Vette-SA's Avatar
78Vette-SA
To Trailing Arm Spring Cushion Cups
